charging help 6 cell packs
I have three gp 3300 packs I got used. I am not getting 3300 out of them on a charge only around 2600 to 2900. But I get better numbers when I dead short them on my smart trays. I charge them with a ice and a mill. pro both at 4 amps. Is there any hope for them or do I need to start looking for new packs?
On the mill. pro what is the peak detection for the nimh is you can't change it in that mode can you?
Sounds like everything is fine the way it is to me, getting 2900 into them is plenty enough. Any more and they may get to hot which isn't good anyhow and possibly pop em which definately isn't good.
Tech Legend
How do you do your charging process? are you traying them prior to charging them so you equalize all the cells prior to charging?
I know that if you don't do this, you may experience what you are seeing. I am seeing this with two stick packs that were race quality GP3300s when they were side by side but got set to starter box duty. They went from there 3500 mah common level to about 2800 mah.
Dead shorting as I have experienced will bump up your voltage (what you want for stock) but cut down your runtime. I always had two packs around that I deadshorted and they usually keep around 3300mah for awhile. Good packs.
If they are beater packs, I don't have a problem deadshorting. Good new packs should be good out of the box.
Well I start off by draining them in a 20 amp bulb discharger with cut off switch then tray them in my smart trays at .9 per cell but have messed around and went lower because had one cell in one pack that the light would go off right away but now after setting it to .3 per cell at .9 it stays right with the others and after that put them on a charger at 4 amps.
cycle them it might help...
