Anyone know what head button and carb?
Hi, i was wondering if anyone knows what other head buttons and carbs fit the Picco P7-R EVO? my hobby shop can't get either of those from picco, would other ofna ones fit?
And my other question is; when i run my car, the engine will have great power and lots of smoke for maybe the first 2-3 minutes after the engine has been warmed up then its sounds almost like it is richening itself up on the bottom end, sounds like a goose and has no power until it gets to the point where it will just stall..???? I tryed leaning the bottom end out but it still does the same thing, i also tried richening it as i thought it was leaning itself out but it just makes the low end worse...
Go over the engine/carb then go over it again sealing it up. Size up some Orings that might fit better than the stock ones in the carb. My P7R carb is super reliable and consistent, but the stock Orings arent the best, well some of them at least. So I would check those out before you go out and buy a new carb. I can tell you though that Novarossi or Sirio carbs wont fit.
