Old 09-12-2006, 08:54 PM   #1
spaks's Avatar
Default RC10GT2 question????
alright im sure this has probably been asked but can i get a list of all .12 engines that will work in the new truck im looking at cheap engines to so preferably cheaper engines i was thinkin about this one but the carb looks like its on their wrong??
http://www2.towerhobbies.com/cgi-bin...?&I=LXUJ72&P=7
spaks is offline   Reply With Quote
Old 09-12-2006, 09:04 PM   #2
WheelNut's Avatar
Send a message via MSN to WheelNut
I beleive you need an motor with an SG shaft, so that one wont fit. Plus the GT2 comes with a rear exhaust header, if you get a side exhaust motor (like that CVR) you will need to buy a new header (which is easy to get). The carb on all motors can be flipped around to fit different cars. SO looks for a SG shaft, rear exhaust, rotary carb engine. I think you could use a slide carb (probably doesn't include the linkage for it though) on it as well, but the rotary carb is easier to drive.
•Brad Comis
WheelNut is offline   Reply With Quote
Old 09-13-2006, 11:32 AM   #3
kdub's Avatar
The GT2 will fit other threaded engines like the CV-R. Just the parts in the box are for SG crank, rear exhaust. The truck can accomodate side exhaust motors also with the purchase of the correct manifold.
You will need to get the #2312 SG adapter clutch nut for threaded crank. Then get whatever AE manifold for your engine. The included pipe will work in either case.
Chief Engineer, Schelle Racing Innovations, SchelleRacing.com - Team Associated - Reedy - JConcepts - Sanwa - MIP - StickyKicksRC - UpGradeRC - Darkside Designs
kdub is offline   Reply With Quote
Old 09-13-2006, 10:55 PM   #4
spaks's Avatar
so if i get the standard crank and the optional clutch nut will i have to cut the crank like on the old gt??
Old 09-14-2006, 06:50 AM   #5
Kevin Boyle's Avatar
Kurt,
Will the current part #7737 Rear-Exhaust Manifold be used in the kit?
Kevin Boyle
Kevin Boyle is offline   Reply With Quote
Old 12-01-2006, 12:36 PM   #6
Thumbs up
Just grind down the engine-brace. It works fine and you can use whatever engine you want.
RC10GT2 question????-rc10gt2throttlelinkage1.jpg   RC10GT2 question????-rc10gt2throttlelinkage2.jpg   RC10GT2 question????-rc10gt2throttlelinkage3.jpg   RC10GT2 question????-rc10gt2throttlelinkage4.jpg
mgreen is offline   Reply With Quote
Old 12-01-2006, 01:03 PM   #7
Doug D's Avatar
Trader Rating: 54 (100%+)
Wow! A slide carb w/ a TZ.....that truck will probably be a handful
Doug D is offline   Reply With Quote
Old 12-03-2006, 04:11 PM   #8
I'm running it on a dirt oval track with a EDM body. I put Nitro TC3 shocks up front and put the front shocks in the rear.
Old 12-03-2006, 05:14 PM   #9
I would be more concerned about the lack of brake linkage...
Serzoni is offline   Reply With Quote
Old 12-06-2006, 04:13 AM   #10
I can lock the brakes with easy. No problems and everything is holding up. The only thing I'm dealing with is loosing the cvd pins. But Heat-shrink took care of that problem.
RC10GT2 rfree02 Australia For Sale/Trade 0 06-15-2008 01:17 AM
Associated RC10GT2 + RB V12 rfree02 Australia For Sale/Trade 2 05-21-2008 05:32 AM
RC10GT2 wanabefast R/C Items: For Sale/Trade 8 05-19-2008 04:55 PM
FS/FT RC10GT2 venom*one R/C Items: For Sale/Trade 25 12-06-2007 05:06 AM
RC10GT2 ca-tn R/C Items: For Sale/Trade 1 11-07-2007 11:26 AM
