Old 09-07-2006, 06:51 PM   #1
Default clutch bearing problems
I'm experiencing problems with clutch bell bearings exploding. I've tried all different kinds of bearings and clutches, and the only clutches that are working well are the Fioronis. I'm running a Nova P5 in my MBX5 and a Top 528x in my MBX5T- both vehicles are experiencing the same issues. Sometimes the bearings last a little longer than others, but today I ran 3 tanks through my truggy and smoked a set. Some guys I talk to get almost 2 gallons through a set, I'm lucky to get a full main in before they blow. I've tried shimming differently and even had 2 other people set it all up for me. All with the same problems.
Any imput you can suggest would be much appreciated.
cwalters is offline   Reply With Quote
Old 09-07-2006, 06:55 PM   #2
buy better bearings. get some from bocabearings.com
Matt
mat3833 is offline   Reply With Quote
Old 09-07-2006, 07:02 PM   #3
tried them. People tell me that Amains are good but I haven't tried those yet.
Old 09-07-2006, 07:10 PM   #4
idk maby try the ceramics from boca. thats all i can think of.
Matt
Old 09-07-2006, 07:45 PM   #5
WheelNut's Avatar
Send a message via MSN to WheelNut
If you can get a brace that wil stiffen up the centre section of the chassis get it. You definately could be overheating them as well. If your using half throttle a lot that can make the clutch slip tons and create super high temps. Also try setting your gear mesh a bit more on loose side, then you can get more flex out of that area before the clutch bell binds up with the spur gear and exerts tons of pressure on the bearings.
•Brad Comis
WheelNut is offline   Reply With Quote
Old 09-07-2006, 07:48 PM   #6
tried some different types of homeade chassis braces trying to rule out flex and still had problems
Old 09-07-2006, 07:51 PM   #7
WheelNut's Avatar
Its possible you could have bad bearings on your diff, or an out of round spur gear or clutch bell, or a warped diff case.
•Brad Comis
Old 09-07-2006, 07:54 PM   #8
pretty sure that's not it. two different vehicles one of which I just put together yesterday and only ran three tanks through the chassis
Old 09-07-2006, 07:59 PM   #9
this may soind odd but change your engine bearings. a friend had the same problem but not as bad(got about 10 runs) turns out one of the bearings that supports the crank had locked up and was causing major heat.
Matt
Old 09-07-2006, 08:08 PM   #10
we thought about that especially with the P5 but it's doing it in the 528 and I still have problems rolling it on the box it's so new.
Old 09-07-2006, 08:14 PM   #11
WheelNut's Avatar
Just run the Fiorni clutch then, they work really well anyways. Way nicer than the regular 3 shoe aluminums.
•Brad Comis
Old 09-07-2006, 08:26 PM   #12
yeah that's what I'm running on both and I like them so far, they wear really well, just having issues with the bearings
Old 09-07-2006, 09:06 PM   #13
Trader Rating: 28 (100%+)
This guy keeps his stuff perfect just so guys know it's not a maintenance issue. The home-made chassis braces he talked of earlier are nice pieces straight off the lathe.
jbrow1 is offline   Reply With Quote
Old 09-07-2006, 09:19 PM   #14
do you hapen to have a CNC machine? i need to get a motor mount machined
Matt
Old 09-07-2006, 10:10 PM   #15
SpeedBump57's Avatar
My guess is you are not setting/shiming your end play on the clutch bell loose enough. It should be about .40mm of slop, if it is less than that, that might be your problem. It is not happening on the Fiorni's probably because they tend to not generate and much heat as other clutches. They are also one of my favorites.
SpeedBump57 is offline   Reply With Quote
Clutch Bell Bearing Issue 843rcguy Nitro Off-Road 18 08-22-2008 11:09 AM
Clutch Bearing Maintenance pracy Nitro Off-Road 18 06-17-2008 08:15 PM
Complete and total clutch and bearing explosion Revo-lution Georgia Racing 5 05-18-2008 03:29 PM
Clutch bell bearing problems rltanner Nitro Off-Road 14 02-20-2008 01:52 PM
Clutch Bearing Life. tubehead Nitro Off-Road 14 10-20-2007 10:47 PM
