Old 08-28-2006, 05:48 AM   #1
timmey's Avatar
Default What the ?...with Camber links
Hi guy's and bikini clad chick's
Could any one please explain to me what change I get when I move the camber link holes back and throw,I own a t4 and b4 .
I've played with the camber and set it at neg 1.5 and noticed a change but it has me stuffed what moving the holes around does,any help would be a plus
thanks....
hope Jessica here gets ya going.......
see ya timmey
timmey is offline   Reply With Quote
Old 08-28-2006, 06:51 AM   #2
Trader Rating: 28 (100%+)
If you hold the T4 in your hand and push the wheel up and down you can see the tire leaning in and out.
Now if you change the mounting location of the camber mount it will change at what point in your suspension travel the tire starts leaning in and out.
If you go to the b4/t4 forums ask on the charlie perez thread and you will get a much more detailed answer.
jbrow1 is offline   Reply With Quote
Old 08-28-2006, 07:08 AM   #3
tony2's Avatar
i shorter camber link will help the car carve through the corners, where a alonger one will make it point and shoot. in the b4, start with middle in the hub and inner in the brace.
just get the worlds setup from last year, then change to suit, its a really good base setup
Anthony Campbell
Ryper Hobbies l AKA | AE
tony2 is offline   Reply With Quote
Old 08-29-2006, 05:18 AM   #4
timmey's Avatar
Thank's Tony and Jbrow that was what i was after......
see ya timmey
Old 08-29-2006, 06:29 AM   #5
B4Bandit's Avatar
I learned the other weekend that if you raise the ballstud with a ballstud washer it makes a less drastic adjustment than changing the length of the camber link...
B4Bandit is offline   Reply With Quote
Old 08-29-2006, 07:43 AM   #6
tony2's Avatar
have you read the instructions?
it states which way around each adjustment is more drastic,
i thought that the ball stud height gives a more drastic change.
Anthony Campbell
Old 08-30-2006, 04:44 AM   #7
B4Bandit's Avatar
I just did after reading your post...
Under the heading REAR CAMBER LINK in my B4 instruction manual it says:
"Changing the length of the camber link is considered a bigger step than adjusting the ball end height on the rear chassis brace."
RRR REAR CAMBER LINKS brc358 Nitro On-Road 4 07-13-2007 03:53 PM
LST\LST2 RPM Arm and Lunsford Camber Links LosiSuperTruck R/C Items: For Sale/Trade 4 03-20-2007 09:43 AM
Titanium camber links for Losi XXXT MF2 wannabee R/C Items: For Sale/Trade 0 02-02-2007 06:57 PM
Camber out / Elevated Camber ronestar Nitro On-Road 0 07-27-2006 07:24 AM
How do i put links in my sig? 2000xp8 Rookie Zone 1 01-23-2005 11:36 AM
