Old 08-27-2006, 10:00 PM   #1
Team Tekin
Randy Pike's Avatar
Default Sway bar stock?
Hey does anyone know where a good general place to pick up some raw stock to build some larger sway bars for a monster truck. I know piano wire works for 1/10 scale electric but what about the larger stuff. What are the factories making them out of? Is it simply steel rod of varing thickness's or is it a special type of steel,etc.
Randy Pike is offline   Reply With Quote
Old 08-27-2006, 10:02 PM   #2
Scottmisfits's Avatar
Most hobby shops will have varying thickness of piano wire. Plane and heli guys use it primarily. That's probably your best bet.
Scottmisfits is offline   Reply With Quote
Old 08-30-2006, 09:47 AM   #3
Dave G's Avatar
Randy, I know the losi sway bars are made out of spring steel. Not sure if this helps or not, ya cant really bend spring steel to specific shape or it will snap. Can you get piano wire from KS through your shop?
Dave G is offline   Reply With Quote
Old 08-30-2006, 11:18 PM   #4
Team Tekin
Randy Pike's Avatar
Yeah I can but I was looking for something stiffer. The sway bar I'm looking to make is for a 12lb monster truck. I was figuring around .090" or better...
Old 08-31-2006, 09:59 AM   #5
maybe use some drill rod and heat it up at the bends?
adam lancia is offline   Reply With Quote
MTX4 adjustable or stock rear sway bar ? Loveless Nitro On-Road 3 07-22-2008 09:55 AM
WTB Sway Bar Kit for XX-4 Jeff K. R/C Items: Wanted to Buy 0 08-06-2007 04:58 PM
Sway bar ends or xray t2 sway bar bigdog xxx-s R/C Items: Wanted to Buy 1 04-03-2007 07:42 PM
TC3 Sway Bar Kit? RaceFan3 Electric On-Road 10 04-26-2005 08:28 AM
What is a sway bar? zachzachz Rookie Zone 20 08-07-2004 03:39 PM
