Closed Thread
Old 01-15-2007, 02:13 PM   #331
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
You can make metal outdrive savers from brass tubes. Can someone post the specifics on this for those who feel so inclined?
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Cain is offline
Old 01-15-2007, 03:11 PM   #332
There should be absolutely no issue with the plastic outdrive savers with this car. In fact, the old outdrives had more issues and we had to rig our own saves to keep the metal from breaking on large jumps/wrecks. The plactic rings might still be plastic but can probably withstand similar forces to aluminum/brass rings. As long as they are installed properly the outdrives should be fine...I run 9-10 turn motors in my car and I know Glen has run/still runs an 8 turn in his. Neither one of us has had unusual outdrive/diff wear. This should be a decent test, I know I rip on my car and from what Glen says he does too. Outdrive savers would be the last thing I would ever make for this car.
Scyan - what exactly is your problem? I haven't really worn out a diff half..Is this what is happening? I run my slipper all the way down and back one quarter turn..so it is still pretty tight but it still slips before a diff does.
Team Associated, Reedy, LRP, Factory Team, Jconcepts, BFastRc, Darkside Designs, CRCRC.com, Dirt Burner Racing
DanGriffin is offline
Old 01-15-2007, 04:21 PM   #333
No, my problem is not with the savers, not at all ! The dogbones just CHEW in the outdrive, slotting it. I run a 6000mah lipo, mamba max and feigao 7t motor. Tons of amps. MUCH more amp draw than the brushed equivalent. The diffs are fine, I did go through a lot of them in the beginning. They were gluing together. But I realised after speaking with some guys at the track that I was not putting enough diff grease in there and that it was heating.
Scy
Scyan is offline
Old 01-16-2007, 06:50 AM   #334
Tech Legend
Cain's Avatar
DanGriffin: What ESC are you running in your SB V2? also, can you post some pics of it or links to it?
As for the outdrive savers, if you feel they are not needed thats fine, though, considering having "hopup" parts coming from MRC even if they really aren't needed isn't necessarily a bad thing. Some people just like to trick out there vehicle, and if knowing there are alot of hopups out there for the V2 helps increase the number of owners somehow, I am all for it as I really believe in the vehicle and the customer service that MRC provides, even if alot of the extras are more for show. Nothing wrong with having the best looking vehicle!
Cain is offline
Old 01-16-2007, 07:12 AM   #335
I do use the plastic outdrive savers though. My esc is a mamba max esc with a feigao t7 motor.
I will post pics when I'm back home, right in the middle of Melbourne Florida right now.. hehe
Scy
Scyan is offline
Old 01-16-2007, 09:19 AM   #336
Send a message via MSN to Apexs
i would like to get a mamba max esc, just not sure what motors i can use with it and would need to be BRCA legal for the UK any ideas? who else has this esc in their sbv2? and races?
Apexs is offline
Old 01-16-2007, 09:50 AM   #337
The mamba max is a phenomenal little piece of technology. It will run brushed, brushless sensored and sensorless motors. As for your question, I suggest you start another thread or read on it in the brushless forums in forums.radiocontrolzone.com www.ultimarc.com etc etc...
Scy
Scyan is offline
Old 01-16-2007, 12:11 PM   #338
beeanner's Avatar
Trader Rating: 79 (100%+)
Send a message via MSN to beeanner Send a message via Yahoo to beeanner
The outdrive savers job is to stop the outdrives from expanding under load and shatter, and not to prevent outdrive wear. I run some serious motor in my car (7 turns and 8 turns) and have not had a diff problem yet. I do have some slight notches in the diff outdrives, but thats to be expected over time.
I also sugjest using some associated clear lube on the diff balls, and associated black grease on the thurst balls. Use a fairly good amount of clear lube on the diff balls, just wipe off the excess after the diffs are built. Compress the diff spring with pliers a few times before putting it in the outdrive. This will help the diff spring "set" to its normal length. Tighten the diff all the way down, then back it off 1/8 of a turn. Thats my normal setting and my diffs are silky smooth and have not melted/blown up ect.
Hope this helps in some way.
Glen Bean
beeanner is offline
Old 01-16-2007, 01:39 PM   #339
Bean, when you screw the diffs in all the way. Do you mean that you actually compress the spring all the way then back 1/8 of a turn ? I just dont know when to stop screwing it in...
Scyan is offline
Old 01-16-2007, 02:31 PM   #340
beeanner's Avatar
Yep, you will feel the spring bottom out on you. Basicly just slowly crank down the diff bolt till you start to feel some resistance. Thats when you know the sping is fully compressed. Work the diff back and fort a few times then check the diff screw to make sure its fully tightened. Then just back the diff screw off about 1/8 to 1/4 of a turn. Usually 1/8 is pretty good.
Becarefull not to crank down too hard on the diff screw, or else you could break it. Just as you start to feel the screw getting hard to turn is plenty.
beeanner is offline
Old 01-17-2007, 01:44 AM   #341
You can use any ESC in the UK. Speedos dont need to be homologated. You will need to run a sensored motor though. As far as I'm led to believe all brushless motors will work with the Mamba Esc, and in a couple of years when sensorless becomes legal, we'll all be running sensorless motors so you wont need to upgrade your speedo
vroomtshh is offline
Old 01-17-2007, 04:28 AM   #342
im asking what motors will work with the esc that are brca legal, i will be getting the mamba max esc no matter what.
Apexs is offline
Old 01-17-2007, 04:38 AM   #343
PerformanceRC's Avatar
I think you can program any brushed and brushless motor with the Mamba just find out whats legal and take a pick.
PerformanceRC is offline
Old 01-28-2007, 04:43 PM   #344
Anyone have pics of there layouts?
Old 01-29-2007, 12:47 PM   #345
jko
Cain, you mentioned there's an faq for the v1 buggy, where is that faq? I tried searching on google and couldn't find it.
jko is offline
Closed Thread
Academy SB pro 4wd buggy vtec_chump R/C Items: For Sale/Trade 6 12-21-2008 09:43 PM
Academy SB V2 PRO 4wd buggy $125 sipaboy R/C Items: For Sale/Trade 5 11-26-2007 08:39 AM
academy 2wd buggy??? b-man777 Electric Off-Road 1 12-19-2006 08:24 AM
Academy SB V2 1/10 EP Buggy HPC II Malaysian R/C Racers 12 08-30-2006 11:49 PM
Academy SB 4wd Buggy Cain Electric Off-Road 12 04-15-2004 10:55 AM
