Closed Thread
Old 12-30-2006, 04:41 PM   #301
frankiecmgt's Avatar
Trader Rating: 77 (100%+)
SCYAN...DO WHAT I NOW DO AND RUN THE V1 DIFFS....STEEL OUTDRIVES.. . I HAVE NOT HAD A PROBLEM IN MY V2 WITH THOSE DIFFS..AND THEY DROP RIGHT IN...FRANKIE
I AM A BELIEVER IN THE R/C TECH UN-WRITTEN RULE " HE WHO HAS THE LOWER FEEDBACK SHIP'S FIRST "......
frankiecmgt is offline
Old 12-31-2006, 04:18 AM   #302
PARK YOUNG HUN's Avatar
Send a message via MSN to PARK YOUNG HUN
Default hello!!!
Hello ?
It is Korea academy team driver park young hun.
It is sb v2 that I am using.
Many be active .
Receive much puffer New Year ~
Ask many interests about sb v2.
PARK YOUNG HUN is offline
Old 12-31-2006, 09:38 AM   #303
Frankie, I remember trying the v1 diffs in the v2 when i got it and found that the outdrives were too long ? Also, the v1 diff washers wear out in no time... so its a lose lose situation for me. I would LOVE for them to make a str4 pro 2 steel diff like they annouced earlier !!
Scy
Scyan is offline
Old 12-31-2006, 02:29 PM   #304
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
Nice SB V2.
By V1 washers are you talking about the diff rings? If that is the case, you can use B4 diff rings If I recall correctly. I think they are 1mm too big on the inner diameter, so people just glued them into place. These solved alot of diff wear issues.
Another thing to try on the V1 is use the B4 diff spring. this spring gives more diff action as you bottom out using the stock spring and go from loose to tight when trying to set it. Either that or try some spacers to give the diff alittle more range.
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Cain is offline
Old 01-01-2007, 05:38 AM   #305
academy france's Avatar
CAVE Jean François joined the TEAM academy France with the SBV2 PRO for the season 2007
great prize list
2° champion of France 2006
2° champion of France 2005
champion of France 2004
with the great experiment of this pilot the SBV2 will be one of the cars has to follow over the season 2007 to France
http://team.academy.france.neuf.fr/
academy france is offline
Old 01-02-2007, 01:04 PM   #306
Dave G's Avatar
Park Young Hun: Car looks good, cant wait to see what the US drivers think of the new car!
ACADEMY FRANCE: Congratulations on acquiring such a top notch driver!!
DAVE GRABOSKI...Brings his own soap to the track...
Need a body painted, pitboard designed, Custom Shirt? www.facebook.com/dgraboskidesigns
www.dgdesigns.org
DG Designs, Team Scream, TQ Wire
Dave G is offline
Old 01-03-2007, 08:31 AM   #307
DrunkMike's Avatar
Trader Rating: 22 (100%+)
was looking to get some aluminum parts for my sb pro any ideas where o ger them. ear hinge pin mounts and rer hub carriers
AE TC6 IM GIVING IN AND RUNNING RUBBER TIRE
CRC GEN XL
BRP
NORCARRACING.COM
DrunkMike is offline
Old 01-03-2007, 08:46 PM   #308
the rear aluminum hinge pin mount you can order from MRC, it is an academy part. The PN is 98VP T009 for the 3* toe mount.
I'm not sure if anyone makes aluminum hubs for the car. I'm not sure if there is a need to they have so much material on them.
Team Associated, Reedy, LRP, Factory Team, Jconcepts, BFastRc, Darkside Designs, CRCRC.com, Dirt Burner Racing
DanGriffin is offline
Old 01-04-2007, 08:32 AM   #309
DrunkMike's Avatar
what about aluminum or titanium tie rods. all i saw was steel
CRC GEN XL
BRP
NORCARRACING.COM
Old 01-04-2007, 10:31 AM   #310
Dave G's Avatar
DrunkMike: You can use the ACADEMY t6 grade aluminum ones Part# 98VXB T003 Or you can find a similar set of Titinium ones from Lunsford. Good luck!
www.dgdesigns.org
Dave G is offline
Old 01-04-2007, 12:38 PM   #311
DrunkMike's Avatar
thanks dave, ive tried searhing and come up with nothing, and im one of the only people left in the world who still has dial up so when i think i found something it takes foreever to get to.
CRC GEN XL
BRP
NORCARRACING.COM
Old 01-04-2007, 06:28 PM   #312
The AE B3 turnbuckles fit without too much problem. So any lunsford or factory team buckles of same size/set would work. I would imagine B4 buckles are pretty close, but I think there is a longer pair?
Old 01-04-2007, 08:13 PM   #313
DrunkMike's Avatar
if i get the b3 turnbuckles do i need new ball cups???
CRC GEN XL
BRP
NORCARRACING.COM
Old 01-04-2007, 08:16 PM   #314
Pierre-Olivier's Avatar
I use them
http://www2.towerhobbies.com/cgi-bin...?&I=LXDAK9&P=7
With the nice wrench
Pierre-Olivier is offline
Old 01-04-2007, 08:20 PM   #315
you should be able to use the standard size losi/AE ball cups. Check though, pop them on your car. If there is a lot of slop or binding use the academy ones from the kit.
Closed Thread
Academy SB pro 4wd buggy vtec_chump R/C Items: For Sale/Trade 6 12-21-2008 09:43 PM
Academy SB V2 PRO 4wd buggy $125 sipaboy R/C Items: For Sale/Trade 5 11-26-2007 08:39 AM
academy 2wd buggy??? b-man777 Electric Off-Road 1 12-19-2006 08:24 AM
Academy SB V2 1/10 EP Buggy HPC II Malaysian R/C Racers 12 08-30-2006 11:49 PM
Academy SB 4wd Buggy Cain Electric Off-Road 12 04-15-2004 10:55 AM
