Closed Thread
Old 12-28-2006, 11:08 AM   #286
1armed1's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to 1armed1
Cain,
I ran a stupid fast 10x1 at Planet Rc and that track is VERY high grip and had no outdrive issues.
The only thing I have done for the out drive savers is to put a extremely small dab of ca on the edge of the saver and the outdrive to better hold it in place.
Be careful to not put to much ca on there or you won't be able to get the outdrive saver off when you need to.
later
Dayton
1armed1 is offline
Old 12-28-2006, 11:59 AM   #287
Pierre-Olivier's Avatar
I ran SS5800 and the diff gear stip ????
How many shim you put each side?
P-0
Pierre-Olivier is offline
Old 12-28-2006, 02:10 PM   #288
1armed1's Avatar
Pierre,
try 2 shims on the gear side and 1 on the other.
I run a lot more power than the 5800 has and have had no problems with that shimming.
later
Dayton
1armed1 is offline
Old 12-28-2006, 02:30 PM   #289
Send a message via MSN to Apexs
Originally Posted by Dave G
Apexs: The whole idea of having an aluminum/plastic outdrive saver is so that when the outdirve itself is under load that it doesnt expand and shatter. The sleeve that slips over this assembly stops this from happening.
Hope this helps.
how about a rubber cover then to keep it in place better and also to keep dirt out? i dont like the idea of having to keep gluing the savers to keep them in place and mine are always coming loose. was just an idea, i dont have a clue, i have not even had the chance to break my car yet
Apexs is offline
Old 12-28-2006, 02:38 PM   #290
If the savers are installed properly, they shouldn't come off. There are little pins in them so if the sleeves start backing out they should stop when they get to the driveshaft pin.
Also, the shimming of the diff isn't really a science. When new I would say start fairly loose, but when the gears break in this might be too loose. So if you hear clicking every now and then open them up and move the diff over a shim. If you make it too tight you should be able to tell. The gearbox will sound crunchy and not be very free. Also, with the motor installed you can take a side (front or back) and spin both tires with a fair amount of force. If you hear any clicking it is too free and you need to tighten the gear. This isn't perfect because you can't apply the same forces the track gives your car on the bench but it is somewhere to start.
Team Associated, Reedy, LRP, Factory Team, Jconcepts, BFastRc, Darkside Designs, CRCRC.com, Dirt Burner Racing
DanGriffin is offline
Old 12-28-2006, 02:55 PM   #291
maybe i have installed my savers wrong then, any close up photo or something i could see? that my give me an idea, thanks
iv just tured them around, did have them this way to start with but it did not look right so i put them the other way, i see now how this stops them coming off but they can still move
Apexs is offline
Old 12-28-2006, 03:51 PM   #292
Default spares?
what parts do you find yourselves replacing the most? what spares do you carry?
So far I have installed,
ACDVT001 Rear Universal Drive Shaft Set
ACDCPB235 Graphite Upgrade Kit
I also have these but have not installed them, thought I would see how the car handles without them first, so I can see the difference.
ACDRGT011 Shock Set
ACDVXBT004 Shock Set
ACDVPT009 Centre One-Way Cup and Shaft.
Worth replacing the arm mounts? with purple aluminium ones?
can anyone tell me what parts fit the sbv2 from these,
Lunsford parts
Apexs is offline
Old 12-28-2006, 04:06 PM   #293
Kropy's Avatar
Send a message via AIM to Kropy
Originally Posted by Apexs
anyone have any photos of there SBV2 Paint jobs?, maybe start a new thread?
Happy holiday
Here are a few pics of one that I painted up for RC Driver Magazine.
ACADEMY New SB V2 4WD Buggy-kolors-kropy-230.jpg   ACADEMY New SB V2 4WD Buggy-kolors-kropy-231.jpg   ACADEMY New SB V2 4WD Buggy-kolors-kropy-232.jpg
Dale "Kropy" Kropaczewski
Kolors by Kropy
Postman, Save a spot on the stand for me
Kropy is offline
Old 12-28-2006, 04:17 PM   #294
Kropy - looks awesome as always!
Apex - here is a pic thanks to oople. http://www.oople.com/rc/photos/acade...ages/sb04.html
You can see the flat side is facing outward. There is a round side and a flat side on the savers. The round should be facing toward the diff gear.
Old 12-28-2006, 04:21 PM   #295
Kropy's Avatar
Thanks Dan.
Kolors by Kropy
Kropy is offline
Old 12-28-2006, 04:23 PM   #296
Kropy, nice job thanks for posting the pics
Dan, thanks again iv now got them on the right way, thats the only pic in the manual i thought looked strange.
Apexs is offline
Old 12-28-2006, 05:16 PM   #297
1armed1's Avatar
oops
I guess I have been running mine backwards.
1armed1 is offline
Old 12-28-2006, 06:20 PM   #298
hey guys, www.fastraxxhobbies.com now has online shopping. So there is another source for MRC/Academy kits and parts. If they don't have it in stock they can get it for you!
Old 12-30-2006, 12:33 PM   #299
Default Spares?
can anyone help with my questions in post 292?
http://www.rctech.net/forum/showpost...&postcount=292
also does anyone make a mounting plate that fits under the servo? iv noticed it does not sit stright due to the battery slots on the chassis and i would like it to
Thanks,
Happy new year all
Apexs is offline
Old 12-30-2006, 03:27 PM   #300
There are 3 v2's at our track and here are the parts most often replaced...
I myself have broken 2 front C hubs. And I keep stripping the rear outdrive cups.... Otherwise, nothing at all.
The others have broken the front a arms and the front kickup, where the arms attach themselves...
Thats pretty much it.
Scy
Scyan is offline
Closed Thread
Academy SB pro 4wd buggy vtec_chump R/C Items: For Sale/Trade 6 12-21-2008 09:43 PM
Academy SB V2 PRO 4wd buggy $125 sipaboy R/C Items: For Sale/Trade 5 11-26-2007 08:39 AM
academy 2wd buggy??? b-man777 Electric Off-Road 1 12-19-2006 08:24 AM
Academy SB V2 1/10 EP Buggy HPC II Malaysian R/C Racers 12 08-30-2006 11:49 PM
Academy SB 4wd Buggy Cain Electric Off-Road 12 04-15-2004 10:55 AM
