Closed Thread
Old 12-19-2006, 01:17 PM   #256
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
Everyone must be getting resumes ready :P
ttt
Maclin | VP-Pro USA
BillyCaldwell is offline
Old 12-20-2006, 02:54 PM   #257
Pierre-Olivier's Avatar
Im the only one with command difficulty?
Not able to have body, lower arm, knuckle, steering brace, front burkhead...
I miss race after race
I like this buggy but WHERE IS THE SPAIR PIECES!!!!!!
Academy WAKE-UP!!!!!!!!!!!!!!!!!!!!!
I'm thinking about other alternative. Like buy from Australia.
That make me sad holiday time
Pierre-Olivier is offline
Old 12-20-2006, 03:05 PM   #258
SoonerNate's Avatar
Pierre, if you are looking for assistance getting parts I would suggest the following:
1.)Post where you live and what supplier you are having difficulties with so that someone can help you.
2.)Send a private message or email directly as a common courtesy to give the offending party the opportunity to make things right before posting on a public forum.
SoonerNate is offline
Old 12-20-2006, 03:10 PM   #259
beeanner's Avatar
Trader Rating: 79 (100%+)
Send a message via MSN to beeanner Send a message via Yahoo to beeanner
Contact Dave at this e-mail - [email protected]
He can help you with the parts problem. And I agree with Soonernate, post some information on where you are trying to get your parts from so that we can help resolve your issue. Dave at MRC can help you with anything you need. MRC prides itself on customer service and support an they will be able to assist you with any parts you need.
beeanner is offline
Old 12-20-2006, 03:18 PM   #260
beeanner's Avatar
Pierre - If you are unable to find the parts you need I can possibly send you some of my personal spares I carry around. Let me know what you need.
beeanner is offline
Old 12-20-2006, 06:26 PM   #261
BIG thank you gang, i will see with Dave.
Old 12-21-2006, 08:19 AM   #262
Dave G's Avatar
Pierre-Olivier: Check your e-mail. Not sure what the issue is with your Canadian distributor but we have all but 1 of your parts in stock. I dont think "FLAMING " ACADEMY is the answer. Hope this helps!!
DAVE GRABOSKI...Brings his own soap to the track...
Need a body painted, pitboard designed, Custom Shirt? www.facebook.com/dgraboskidesigns
www.dgdesigns.org
DG Designs, Team Scream, TQ Wire
Dave G is offline
Old 12-21-2006, 01:56 PM   #263
Humm the Hobby shop said to me is from Academy the piece are out of stock.
And they don't know when it will be in stock.
P-0
Old 12-22-2006, 05:02 PM   #264
Dave, I had spoken to you about them in the past. That friggin dealer here in Montreal, Quebec charges more than msrp and is a B%tch to deal with. They are unsupportive and quite arrogant. You said you might be able to do something about it and never got back to me. I somewhat understand why PO is pissed off. They are really bad and he got enough. I also asked him to verify with you directly in the future.
I dont know what you guys can do regarding that, but they are really bad. Thats for sure.
Scy
Scyan is offline
Old 12-22-2006, 05:07 PM   #265
Hummm...
I think Dave will call the hobby-shop to see with us
Old 12-22-2006, 08:36 PM   #266
Dave is out until the 27th. If he hasn't already spoken to you guys, remind him next Wed.
BTW, everyone have a happy holidays!
Team Associated, Reedy, LRP, Factory Team, Jconcepts, BFastRc, Darkside Designs, CRCRC.com, Dirt Burner Racing
DanGriffin is offline
Old 12-23-2006, 06:29 AM   #267
Send a message via MSN to Apexs
does anyone have any blank body templates that i could print out, that i could use to design my paint finish ideas on?. all i need to do now is tighten the diffs and paint then body
while testing the electronics i noticed the steering has a lot of free movement / play, is this normal? the right side that has the spring on, im able to move the spring up and down about 3-4mm, should it not all be very tight?
Apexs is offline
Old 12-23-2006, 01:16 PM   #268
The spring should be tight between the purple nut and the steering ackerman arms. Tightening the nut (moving it up on the shaft) tightens the servo saver, it sounds like that is all you have to do.
When you tighten the diffs, go all the way in (don't break anything though..be aware you can overcrank the bolt) and out about an 1/8th turn. You can either break it in on the bench or run it a few laps and they probably will need it again. Don't go a whole pack on a track before you check the diffs if they are new. They loosen up pretty quickly until they are seated. So run a few laps, check them by tightening them all the way down and then back an 1/8th. Then run a few more laps and do the same thing. When they stop loosening for the most part you are good and can run a whole pack w/o problems. They are sensitive until they are broken in, but just be careful and you should be fine. Once they are broken in maintenance on them is very minimal. Enjoy the car..its a blast
Have a good holiday too!
Old 12-23-2006, 02:05 PM   #269
Nice one Dan thanks, happy holiday
Apexs is offline
Old 12-23-2006, 05:50 PM   #270
Do you have news about the SBV2 Pro?
Coming in January Wainting list???
Closed Thread
Academy SB pro 4wd buggy vtec_chump R/C Items: For Sale/Trade 6 12-21-2008 09:43 PM
Academy SB V2 PRO 4wd buggy $125 sipaboy R/C Items: For Sale/Trade 5 11-26-2007 08:39 AM
academy 2wd buggy??? b-man777 Electric Off-Road 1 12-19-2006 08:24 AM
Academy SB V2 1/10 EP Buggy HPC II Malaysian R/C Racers 12 08-30-2006 11:49 PM
Academy SB 4wd Buggy Cain Electric Off-Road 12 04-15-2004 10:55 AM
