Closed Thread
Old 11-25-2006, 08:57 AM   #196
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
The diffs do open up alittle easier than what I was used to , so I had to really pay attention to setting them up correctly after the first run.
Main thing I did to eliminate the initial chirping was to build the diffs at a tight setting (not locked). After about 2 high speed passes I went and reset the diffs as they loosened up that quickly. But after resetting them, all was fine.
Are you building them with the stock diff fluid or something else? You may want to try building them with AE diff fluid if you are using the stock fluid as its a much better grade and I was advised by Dave that this should help.
If you are snapping them, have you done any rear droop limiting or the oring trick for the rear axles?
I would like to see MRC / Academy to release an upgrade diff alloy sleeves for high power running. Would be a nice feature as well as possible alloy diffs.
From what I understand there are redesigned rear universals that help with the droop issue. Dave can you confim?
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Cain is offline
Old 11-26-2006, 02:20 AM   #197
frankiecmgt's Avatar
Trader Rating: 77 (100%+)
I AM TOTALY MELTING THEM TOGETHER AND ROUNDING OUT THE OUTDRIVES. I HAVE TRYED DIFFERENT GREASE ( STOCK,AE,LOSI,NIFFTECH ) WHEN I BUILD THE DIFFS. I AM RUNNING A BRUSHLESS 5.5 WITH A ORION LI-PO IN IT. I NEVER HAVE A PROBLEM WITH THE FRONT DIFF JUST THE REAR. ALSO I AN RUNNING THE UNIVERSAL KIT IN THE REAR AND NOT DOGBONES. I HAVE SET THE DROOP SO I HAVE PLENTY OF THE UNIVERSAL IN THE CUP. THANKS FOR ALL THE HELP GUYS....FRANKIE
I AM A BELIEVER IN THE R/C TECH UN-WRITTEN RULE " HE WHO HAS THE LOWER FEEDBACK SHIP'S FIRST "......
frankiecmgt is offline
Old 11-26-2006, 06:02 AM   #198
Mike Kazz
Guest
Posts: n/a
Make sure the outdrive collars are on correctly per manual. Also, If your diff is maelting, make sure that the tention in the spring is still good. For all my cars, When not using them for a while, I loosen the diffs and release the tention in the springs... Do not grease the outdrives also... JUST IN CASE...
Old 11-26-2006, 07:53 AM   #199
Tech Legend
Cain's Avatar
Mike, why wouldn't you put the diff fluid (grease I am assuming was meant) on the diff as stated in the manual?
If you have the newer style universals, does it look like you have more room between the universal end that goes into the outdrive and the flat surface across from it of the outdrive? If so, maybe try a different diff spring like the B4 diff spring? We did this trick on the SB V1s as originally the diff nuts would bottom out and have no diff action or worse wouldn't tighten up enough. The B4 spring was bigger with more space between the coils so you could tighten it down more and still have "diff" action.
May be worth a look.
Cain is offline
Old 11-26-2006, 08:11 AM   #200
It's been almost a year since I reviewed the V2 here
I gave the car a much lower rating than the sb-sport, because of
- center driveshaft: Didn't fit the joints well, had to be ground a bit, bad material combination since its ends should have been plastic (which didn't hold up and was replaced by steel pins that damage the outdrives, driveshaft setup in general seemed very carelessly constructed.)
- rear end: less articulation than front end. Diff outdrives too short, even shorter on the right side making the driveshafts fall out. Ridiculously thick universal drive shafts (4mm steel) would bind and break the outdrives unless there are a lot of suspension limiters (inside & outside) used, effectively crippling many attempts to change the setup.
- price: 270 Euros (300 $) is just not right by any measure for the basic, flawed V2 kit. Though I understand that the pricing was Academy Europe's/Germany's genuine idea.
Now from what I've read on the last few pages, there seem to be some fixes - but there's no definitive statement that they actually rectify the issues.
So, can anybody help me out? I'm not up to date any more.
re-inferno is offline
Old 11-26-2006, 03:12 PM   #201
TonysScrews's Avatar
Originally Posted by PerformanceRC
Tonys screws what does the screw pack weigh?
Do you want the weight of the complete kit in the packaging?
Tony P.
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline
Old 11-26-2006, 05:08 PM   #202
Tony - is the kit for the standard sport or the carbon upgrade? The carbon top plate is counter sunk and the FRP isn't. So they would have to be different screws.
Team Associated, Reedy, LRP, Factory Team, Jconcepts, BFastRc, Darkside Designs, CRCRC.com, Dirt Burner Racing
DanGriffin is offline
Old 11-27-2006, 02:26 PM   #203
PerformanceRC's Avatar
Tony i was looking for the weight of the screws themselves.
PerformanceRC is offline
Old 11-27-2006, 04:58 PM   #204
Hi Dan,
I just found out about the carbon upgrade. The TS-SBV2 screw kit will be for the SB Sport V2. I will also put together another kit for the carbon upgrade (TS-SBV2PRO) that will have flat heads instead of button heads for the upgraded parts.
Thanks and best regards,
Tony P.
Tony P.
Tonys Screws LLC
Old 11-27-2006, 05:04 PM   #205
The screw kit comes with 126 pieces. The car only uses @101 pieces so I supply extras. The screws are Grade 12.9 black oxide alloy steel. They are the strongest screws you can buy for our R/C application with a tensile strength of 174,000 psi minimum. The screws also have a deeper socket than many others that allows the hex driver to get a better bite on the screws. All the screws come individually bagged and labeled in a re-sealable zip-lock bag and I also include some Tony's Screws decals and business card in every kit .
If you want, I can still weigh the screws but it'll be the 126 pieces.
Best regards,
Tony P.
Tonys Screws LLC
Old 11-28-2006, 02:32 AM   #206
Can people in the UK buy your screw kits?
vroomtshh is offline
Old 11-28-2006, 10:08 AM   #207
ABSOLUTELY!
My shopping cart provider's software doesn't have an option for International orders, so I put a note on the front page to just email me your orders. I ship most International packages via USPS Global Priority mail for $6 (if I can use the USPS GPM flat rate small envelope, otherwise I use USPS Airmail Letter Post and will email you back a shipping quote). What it costs me is what it costs you. I do not believe in making money off shipping on customers.
I ship International orders out 6 days a week.
Best regards
Tony P.
Tonys Screws LLC
Old 11-28-2006, 03:38 PM   #208
beeanner's Avatar
Trader Rating: 79 (100%+)
Send a message via MSN to beeanner Send a message via Yahoo to beeanner
The center driveshaft has been reworked some and fits in the drive cups perfectly.
The universals also received a major overhaul and have been totaly redone. They no longer bind and break the outdrives. They are now a stronger, yet smaller size. And travel limiters can be used to once again tune the suspension and not the depth of the dogbone in the diff outdrive.
As far as price, the V2 Pro car will be priced very well against other makes of 4wd cars. Probably much cheaper. We will have to wait and see. As far as the flaws you speak of, those have been taken care of. MRC/Academy is fully driven to producing a world class 4wd car, and they are proving that day after day.
All in all, the SBV2 can compete with the Yokomo's, Losi's, BJ4's, ect. And for far less. This car is a winner out of the box, and im looking forward to putting mine in the winners circle.
beeanner is offline
Old 11-29-2006, 03:29 PM   #209
Dave G's Avatar
Just wanted to let you all know that another shipment has been made to Stormer Hobbies, I also sent him a bunch of pictures for his website as well, in the hopes that it will make all of your lives easier. Hope all is well, talk to you soon!
DAVE GRABOSKI...Brings his own soap to the track...
Need a body painted, pitboard designed, Custom Shirt? www.facebook.com/dgraboskidesigns
www.dgdesigns.org
DG Designs, Team Scream, TQ Wire
Dave G is offline
Old 12-01-2006, 03:00 PM   #210
Do you have a pic of the Carbon arms that you can post on here?
Closed Thread
Academy SB pro 4wd buggy vtec_chump R/C Items: For Sale/Trade 6 12-21-2008 09:43 PM
Academy SB V2 PRO 4wd buggy $125 sipaboy R/C Items: For Sale/Trade 5 11-26-2007 08:39 AM
academy 2wd buggy??? b-man777 Electric Off-Road 1 12-19-2006 08:24 AM
Academy SB V2 1/10 EP Buggy HPC II Malaysian R/C Racers 12 08-30-2006 11:49 PM
Academy SB 4wd Buggy Cain Electric Off-Road 12 04-15-2004 10:55 AM
