Closed Thread
Old 11-13-2006, 08:56 AM   #151
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
No problem. We were just proud of our boy. He needed a good weekend after Hutch.
Maclin | VP-Pro USA
BillyCaldwell is offline
Old 11-13-2006, 10:00 AM   #152
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Car looked good for sure. Even on that very rough track.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline
Old 11-13-2006, 08:14 PM   #153
PerformanceRC's Avatar
SBV2 PRO due to be released January!
PerformanceRC is offline
Old 11-13-2006, 08:33 PM   #154
It was nice seeing that car all weekend
Old 11-13-2006, 08:53 PM   #155
Yup, definitely something to thing about for next year. Does RC Pro run a wheeler class?
Maclin | VP-Pro USA
Old 11-13-2006, 10:30 PM   #156
Dave G,
The Pro kit will be available in the US exactly when?
XXX-CR, XXX-T CR, XXX-SCT (Kertez conversion)
CRCRC.COM
Sneaky Pete Racing
Hammer Racing
Bike racer is offline
Old 11-14-2006, 07:20 AM   #157
Yes the RC Pro series runs a wheeler class. Hoping to have one in time for the first race.
Old 11-14-2006, 07:24 AM   #158
Trader Rating: 54 (100%+)
What is the standard Spur gear that comes in the SB V2, and what gears are available? I am thinking about getting one of these to build a truggy as Kazz's pics got me hooked.....Just curious on the gearing available or what other spur's fit? On Stormer there is only 78T & 80T Spur.
Also, Kazz, any details/tips you might want give me or or to my email would be appreciatted: [email protected]
James
jsmax is offline
Old 11-14-2006, 07:36 AM   #159
Also, bean, if you wouldn't mind sending me your setup for Mikes Hobbyshop track to use as a starting setup I would appreciate it. I was not able to make it to the race Saturday but I dropped by and saw you running and your car looked hooked up. [email protected]
jsmax is offline
Old 11-14-2006, 07:37 AM   #160
The car comes with 70-80 in 2 teeth intervals. So the kit comes with 6 total spur gears.
Team Associated, Reedy, LRP, Factory Team, Jconcepts, BFastRc, Darkside Designs, CRCRC.com, Dirt Burner Racing
DanGriffin is offline
Old 11-14-2006, 07:41 AM   #161
Would be the standard gearing for the buggy with a 5.5, or at least a close starting point?
jsmax is offline
Old 11-14-2006, 08:23 AM   #162
I'm running a 6.5 with 80 spur gear and 15 - 17 pinion depending on the track.
vroomtshh is offline
Old 11-14-2006, 08:57 AM   #163
beeanner's Avatar
Trader Rating: 79 (100%+)
Send a message via MSN to beeanner Send a message via Yahoo to beeanner
jsmax - This is the setup I ran at Mikes:
Front - Associated #2 pistons, 37.5wt oil, associated silver spring. 0 limiters. outside on tower, middle on arm. -1 degree camber. front diff with oneway on shaft. bones lvl. #4 camber link positon.
rear - Associated #1 pistons, 32.5wt oil, associated green spring. 1mm limiter. 2nd hole in on tower, inside hole on a-arm, bones lvl, 2degree anti squat, 3 degree toe in. 4-a camber link. (top of hub carrier ground down .060 to allow for ballstud height adjustment) 2 washers under ballstud.
rear hubs were also ground down on each side .030 to allow wheelbase adjustment. ran hubs in middle.
Full 6 cells on left hand side, electronics on right. 8x1 geared 16-80. Losi pink x2000's rear, losi pink tapers front. Proline inside jobs would probably be a little more consistant front and rear though.
I also tried academy 2 hole pistons in front and rear, with 40wt f, 35wt r oil, same springs. car felt good, little choppy in the super rough parts though.
Car had lots of lowspeed steering and a little bit of a push at high speed. I will be doing alot of experimenting the next few weeks and post up on my findings.
Was a great weekend. car was super fast and so easy to drive. Really looking forward to the next race! Thanks to my gang and Dave G at MRC for all the help!
beeanner is offline
Old 11-14-2006, 09:05 AM   #164
Thanks, I think I am gonna have to try this car. I like how the xx4 handles but accelaration is horrible....I like the speed/accelaration of the ZX-5 but was very fragile. Maybe the V2 will be a good middle ground. May have to get 2 of them to make one a truggy.
jsmax is offline
Old 11-14-2006, 12:45 PM   #165
Default V2
James,
Let me know if you get one and I may split the shipping on this.
Send me an email with your number so we can talk.
Scott
OldRc10 is offline
Closed Thread
Academy SB pro 4wd buggy vtec_chump R/C Items: For Sale/Trade 6 12-21-2008 09:43 PM
Academy SB V2 PRO 4wd buggy $125 sipaboy R/C Items: For Sale/Trade 5 11-26-2007 08:39 AM
academy 2wd buggy??? b-man777 Electric Off-Road 1 12-19-2006 08:24 AM
Academy SB V2 1/10 EP Buggy HPC II Malaysian R/C Racers 12 08-30-2006 11:49 PM
Academy SB 4wd Buggy Cain Electric Off-Road 12 04-15-2004 10:55 AM
