Old 08-21-2006, 06:04 AM   #16
Originally Posted by o.s. power
noWhy in God's name you would mention gold and HT when they haven't been made in over 5 years?
I sometimes still use Gold/ ht front tires, especially on really soft indoor tracks. They're great
Wouter.Z is offline   Reply With Quote
Old 08-21-2006, 06:36 AM   #17
Trader Rating: 14 (100%+)
Originally Posted by turd ferguson
WHAT!!! Not in the Midwest. Pinks everywhere
agreed
maybe we should use reds instead of pinks since they are softer
o.s. power is offline   Reply With Quote
Old 08-21-2006, 06:39 AM   #18
dirtracer1's Avatar
Originally Posted by Brad_J
What is the color code for Losi tires from softest to hardest? Thanks.
all of the round ones are black.....except for the ones that are blue.
the black ones are usually softer than the blue ones.
Losi 22
Losi 810-e
Losi SCTE
Losi XXX-MF2/CRC SC
B&T R/C - http://b-treman-rc.valp.net/btrchome.htm
dirtracer1 is offline   Reply With Quote
Old 08-21-2006, 07:51 AM   #19
T. Thomas's Avatar
agreed
softest does NOT always equal fastest tire.
T. Thomas is offline   Reply With Quote
Old 08-21-2006, 12:12 PM   #20
killer89's Avatar
Trader Rating: 41 (100%+)
Send a message via AIM to killer89
red, pink, silver
i believe the full lineup would be white, red, pink, silver, blue, gold, HT. I think the blue is between silver and gold...
killer89 is offline   Reply With Quote
Old 08-21-2006, 02:20 PM   #21
Registered User
Kendall Welch's Avatar
red, pink, silver
Kendall Welch is offline   Reply With Quote
Old 08-21-2006, 02:23 PM   #22
Matt Howard's Avatar
best thread ever
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 08-21-2006, 02:25 PM   #23
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Matt Howard
best thread ever
you don't get out much...
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 08-21-2006, 02:26 PM   #24
Casper's Avatar
Trader Rating: 34 (100%+)
Pink is just different! LOL It is not an out door dirt tire. It is an indoor clay tire. The Pink compound has changed over the years. It used to be a lot harder and longer wearing tire then it is now. The newer pink compound has great clay track traction but does not last as long.
red is softer then silver. Use outdoor.
Pink is different and good indoor clay.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 4.0, TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 08-21-2006, 02:36 PM   #25
TLRacing
Frank Root's Avatar
Perfectly said.
Old 08-22-2006, 03:48 PM   #26
schmelme's Avatar
Like you guys said pinks are just different. The tire itself isnt stretchy like other compounds. But i can say this some tracks pinks are the only thing that gets you around the track.
schmelme is offline   Reply With Quote
Old 08-22-2006, 08:31 PM   #27
W.E.D.Jim's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to W.E.D.Jim
Nobody mentioned Yellow*......or 2.5*?
There is no comparison of PL and TL tires. M3 is "too soft" for blue, or black grooved tracks, so PL made R3, to add durabilty and SOME consistancy to their line. M2 is reserved for monster truck and 1/8th buggy mostly now.
TL tires are the standard for all major events where the track will "Groove", or leave rubber down on the racing line. Reds for almost every track, the only thing that changes is tracks that are nuts run Tapers on 2w, truck and 4w, tracks not quite as good run BK bars on 2w and 4w and King pins on truck....ALL red.
Fronts are normally always silver, except for a few racers who like a TON of steering that run red fronts also. They change between pre scrubs, ex wide 4 ribs and front tapers in 2w and block heads or tapers in 4w. Trucks run tapers or kingpins in silver up front.
When the bite goes away, PL tires shine, since that is when their softness is a benifit, rather then a detriment. They seem to roll under and snap and do things that make them too unpredictable on high bite, but this helps in low traction or low bite.
*Both companies have made tires in the past nobody was ever able to buy, but that is normal when trying to develop a product for the consumer I guess, or trying to win an event like the Worlds by gaining an advantage.
, Jim
www.wedjim.com ...Reopening soon. I'm still painting, just not with 40+ bodies waiting. :)
www.prolineracing.com
www.HarleyDavidson.com
"Nothing but the best!"
W.E.D.Jim is offline   Reply With Quote
Old 03-17-2009, 10:11 AM   #28
My local track is selling TL Tapers in white compound. Apparently they have a bunch of them and are offering them at a discount. I normally run on indoor clay with reds (or JC green) when it's dry and then pink (or JC gold) when it's moist.
What gives with this white compound? How will it compare?
richard.bratton is offline   Reply With Quote
Old 03-17-2009, 11:00 AM   #29
Casper's Avatar
White is one of those inbetween compounds like pink. I have not tried the whites on blue groove yet but I have been running the white 8-rows on my truck at my local indoor clay track. They have pretty good traction up front. I think they are better then the red 8 rows. I have a couple sets of white tapers I want to tryout. I am not quite sure what foam to put in them. They are a stiffer tire then red so not sure they need too much foam in them to run right.
Give them a shot and see how you like them. I have been told they may be a little hard to keep glued to the rim so clean off the bead with some motor spray to make sure the hold release and oils out gone before mounting them. My 8 rows have stayed glued fine with about 10 runs on them so I am not sure how big a problem this might be.
Old 03-17-2009, 11:05 AM   #30
Thanks for the advice Casper! I'll give them a try and let you know how they work out. The tires feel a lot firmer than Red or Pinks so it's really confusing.
Shore, Degrees, Color Code for Foam Tires. R3VoLuTiOn Nitro On-Road 0 03-16-2005 10:18 PM
[COLOR=blue]Brand New Calandra 1/12 Rc Car With Ko Propo Digital Servo [/COLOR] [email protected] Malaysian R/C Racers 1 08-29-2004 11:16 AM
losi spur gear color xxxtracer32 Electric Off-Road 5 07-05-2003 10:35 PM
foam tire color code??? warlord385 Electric On-Road 0 02-03-2003 07:24 PM
