Old 08-19-2006, 01:55 PM   #1
Default Prefilter Oil or No Oil?
What is best oil the prefilter or not? I'm talking off-road 1/8 scale.
Lextek is offline   Reply With Quote
Old 08-19-2006, 02:30 PM   #2
Sluggo's Avatar
Send a message via AIM to Sluggo Send a message via MSN to Sluggo Send a message via Yahoo to Sluggo
Oil that thing up!!
Sluggo is offline   Reply With Quote
Old 08-19-2006, 03:50 PM   #3
Trader Rating: 14 (100%+)
your best bet is to oil it. Even by oiling it, you are not going to lose any performance at all. In the long run it will help keep dirt out of your engine and prolong the life of the filter itself. With the pre filters, don't be afraid to wash them and re use them, since they are thin, all of the dirt makes it way out, use dish soap with lots of degreaser.
o.s. power is offline   Reply With Quote
Old 08-19-2006, 04:33 PM   #4
Pretty much what I thought. Any problem cleaning and reusing the inner filter?
Old 08-19-2006, 06:58 PM   #5
4 filters cost 9 bucks and will probably last you an entire season, if you want to risk dirt in your $300 motor to try and save 10-20 bucks a year, that's your call.
Not trying to be an a hole, but with a thicker filter, trying to clean it will move the dirt closer to the hole, and into your engine.
Old 08-19-2006, 07:36 PM   #6
SpeedBump57's Avatar
Oil it!!!!!!!
SpeedBump57 is offline   Reply With Quote
Old 08-19-2006, 08:01 PM   #7
thanks guys, good info.
Old 08-19-2006, 08:02 PM   #8
I got 6 gallons out of an engine and I cleaned and re-oiled my inner filters. great thing about the way soap works, it traps dirt and grime and grit inside of the soap compound. So, you can waste your 9 bucks on throwing filters away, or save 9 bucks for parts and re-oil them, your call.
Rod
gatermaxx is offline   Reply With Quote
Old 08-20-2006, 12:20 AM   #9
what's $9 going to buy you for parts?
Just curious.
Old 08-20-2006, 04:18 AM   #10
WheelNut's Avatar
Send a message via MSN to WheelNut
Just curious.
9 clutch bell bearings!
•Brad Comis
WheelNut is offline   Reply With Quote
Old 08-20-2006, 06:05 AM   #11
[email protected] Wheelnut!
Old 08-21-2006, 03:35 PM   #12
many of us re-use air filters and have had plenty of luck. IMHO in no way would it put your motor at greater risk IF you can clean them properly.
riverrevo is offline   Reply With Quote
Old 08-21-2006, 04:23 PM   #13
Flying_Ace's Avatar
I found that if I oil my pre filter, my normall filter never gets dirty...
Brady Janson
www.racetechhobbies.com
Flying_Ace is offline   Reply With Quote
Old 08-21-2006, 06:57 PM   #14
Also remember, after you oil it up good, use a towel, or papertowel and squish all the excess oil out of the filter. Working at a hobbyshop, we have found that if there is too much, it will take some power away because the lube (associated stuff anyways) is so thick that it acctually blocks some of the cells on the foam. Just a little tip.
the dirt is offline   Reply With Quote
Old 08-21-2006, 08:05 PM   #15
Z_Schneider's Avatar
Oil the prefilter good and you only have to clean the inside filter maybe once a month. Definately oil it!
~X-ray 808-'10~X-ray XT8-'09~Associated SC10~Kyosho RB5
Sponsors:
~JConcepts~CPR Adrenaline~Shellz custom painting(me)~Team Dirtheaven~
Z_Schneider is offline   Reply With Quote
Which to oil ? Outside prefilter or main filter or both ? nikkor Singapore R/C Racers 4 11-13-2006 05:45 AM
