tech help pls
Old 08-18-2006, 09:22 PM
Default tech help pls
Hi all
I have had my traxxis jato sence x-mas it has been running great ,but now it is not moving. I can reav the engien but it dosent go foward. I have allready replaced the clutch. It has a 2 speed transmission. Now heres the wierd thing when i put some force pushing it back i can tap the gas but then it will just go foward for just inch, im srry but its hard to explain
chad967 is offline
Old 08-19-2006, 04:35 AM
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
Check to make sure your slipper is set right and you still have all slipper pads
Cheers
Drift_Buggy is offline
Old 08-19-2006, 07:22 AM
R40Victim's Avatar
Turn both rear wheels at the same time. Does your clutch bell move? If so, the problem is likely still in the clutch. If it does not move, it's likely further back in the drive train.(check your linkage everywhere, make sure all CVDs of any kind are connected and all drive cups are secured)
R40Victim is offline
Old 08-19-2006, 02:03 PM
i turned both the wheels the clutch bell moves for about 5 or 6 rotations of the wheel, then it stops then whenever turn the wheels back about a 1/4 of an roation i can repeat this process over again. I dont know if this is normal?
chad967 is offline
Old 08-19-2006, 02:27 PM
Cheers
srry im new to rc cars this is my frist gas 1
what is a slipper, what does it look like, what does it do, and how many slipper pads should it have?
ps i tried google all it came up with was complete cars (ive never been good with google)
chad967 is offline
