Old 08-14-2006, 10:39 AM   #1
t4mania's Avatar
Default Battery Charging
I'm using 1400mah nimh 5 cell batteries for my receiver packs. I'm charging these packs at .5amps and discharging at 2amps. Does cycling these packs do any good. I've heard cycling nimh packs doesn't help any? I'm also using a cutoff voltage of 4.0 volts for storage. Thanks in advance!
t4mania is offline   Reply With Quote
Old 08-14-2006, 11:02 AM   #2
killer89's Avatar
Trader Rating: 41 (100%+)
Send a message via AIM to killer89
charging from .5 to 1 A is good. dischage at 1A to 2A. discharge down to 4.5V. Cycling only is good for a pack that is new or hasnt been used in a long while. for storage I would dischage down to 4.5V and then add (charge) 200-300 mah for storage.
killer89 is offline   Reply With Quote
Old 08-14-2006, 02:25 PM   #3
t4mania's Avatar
Thanks Killer, first time I've used these packs and didn't want to screw up and ruin them, thanks again!!
Old 08-14-2006, 05:05 PM   #4
Trader Rating: 14 (100%+)
I use 1400's too and I charge mine at 1.4 amps. Last over an hour too on one charge.
o.s. power is offline   Reply With Quote
Old 08-16-2006, 12:19 PM   #5
t4mania's Avatar
Smile Batery Charging
O.S. Power, the website recommends .5 -1 amp charge rate. 1.4 amps doesn't damage your batteries I guess. Sure would charge quicker over .5 amp!
SC10 4X4 Short Course
SC10 FT 2WD Short Course; FT B4.1 +8mm Buggy
FT T4 Dirt Oval
Silva Concepts R50 Oval
Custom Works Dominator; FT TC3 Trans Am
Old 08-16-2006, 01:37 PM   #6
I know, but the servos work faster.
Old 08-16-2006, 04:53 PM   #7
t4mania's Avatar
Talking
Higher voltage = Faster Servo, thanks O.S.!!
FT T4 Dirt Oval
Old 08-16-2006, 09:41 PM   #8
faster to a point though. You are still limited by how much the BEC in the receiver can pass though.
Battery Charging rf096 Racing Forum 16 06-01-2015 03:24 PM
Charging Ni-Cd battery jayliu1984 Electric Off-Road 8 02-27-2008 11:32 AM
battery charging kracka Rookie Zone 1 11-23-2006 12:50 AM
Battery charging? Maxxcrazy Electric Off-Road 1 05-11-2006 03:31 PM
Battery Charging nerdling Electric On-Road 10 06-21-2005 11:31 AM
