Old 08-14-2006, 12:57 AM   #1
downunder23's Avatar
Default engine pinching.... anyone know?
hi i am in need for more compression in my .21 engine and the hobby shop that does pinching does it to the piston not the sleeve ...what is the best way by expanding the top of the piston or pinching the sleeve?
i am guessing the sleeve way would last longer but what actually lasts longer the piston or sleeve waY?
downunder23 is offline   Reply With Quote
Old 08-14-2006, 08:13 AM   #2
SpeedBump57's Avatar
Hum..........I have never heard of anybody working with the piston. How do you expand the piston?
SpeedBump57 is offline   Reply With Quote
Old 08-14-2006, 09:07 AM   #3
Davidka's Avatar
Trader Rating: 77 (100%+)
I heard a while back that people were using a blunt punch under the piston to get it to mushroom slightly but this method resulted in a broken piston more often than not. It was done before there were good processes to resize the sleeve. I would send your piston and sleeve to OS Rocket or Ray-A-Racing. They both have high quality tooling and presses that do it accurately. Ray A Racing also cleans up the piston a sleeve (polishing) as part of their service.
Old 08-14-2006, 10:35 AM   #4
I will let you guys know how the Rayaracing works out. I just sent a piston and sleeve into them. I am hoping for good results
DAVE BERNATH is offline   Reply With Quote
Old 08-14-2006, 11:04 AM   #5
David I remember the process you are talking about, that was long before my time! LOL I thought Downunder was refering to expanding the Dia. of the piston which seems nutty but you never know. You can't go wrong with the two names listed, both are first class.
Old 08-14-2006, 11:04 AM   #6
Send a message via AIM to trashedmaxx
I had ray do two of my engines with great results.
trashedmaxx is offline   Reply With Quote
Old 08-14-2006, 01:06 PM   #7
Nitroaddicts's Avatar
Dont let them mess with the piston, just the sleeve pinch. I would not go back to them after that reply.
www.NITROADDICTS.com
Get Free T-Shirts with Nitro Points!
Need Track TShirts?
http://www.facebook.com/AmericanGFX
Nitroaddicts is offline   Reply With Quote
Old 08-14-2006, 08:56 PM   #8
arghh's Avatar
so anybody experience with the pinch sleeve..?? whats the performance..do it perform like new one..do u have to repeat the break-in process.. can it last long..how many time can pinch the same sleeve..
i have try pinching my sleeve. it make the sleeve getting oval.. the piston is tight in the sleeve but no good compression.. i just like using combination used piston/sleeve from different engine..ex: sts sleeve + hyper 8 port piston.. and the result more better performance then the pinch formula..
arghh is offline   Reply With Quote
Old 08-14-2006, 10:22 PM   #9
is raya racing in us? same with os rocket?
if so would it cost much to send to them i am in Australia.
Old 08-15-2006, 12:30 AM   #10
Talking engine life after pinch
ok i found out both are in usa just one other thing how long would i expect my engine life to be after the sleeve pinch is done? few galons? or just litres?
i sent mail to both rayaracing and osrocket the biggest cost will be postage so well see how it pans out.
Old 08-15-2006, 12:38 AM   #11
You should be able to get in a few more gallons. You will probably have to go through a small breakin with the pinched sleeve, nothing like when new. I would suggest you do this with the same rod that is in there now and when you are done with breakin replace the rod. The rod is probably already worn and running a engine with a fresh pinch is not going to help it any. This way there shouldn't be any stress on the new rod.
Old 08-15-2006, 01:51 AM   #12
arghh's Avatar
Originally Posted by SpeedBump57
I would suggest you do this with the same rod that is in there now and when you are done with breakin replace the rod. This way there shouldn't be any stress on the new rod.
when breakin new engine, seem the conrod, crank shaft, piston pin and bearing got very hard stress from the very tight piston and for sure that part in the new engine will wore out a little.. is it..
so is it good idea breakin new engine like this.. take out the new engine piston/sleeve only and breakin it in old engine..when have finish breakin period, put back the piston/sleeve to the new engine. so ur new engine got totally no wore out part inside the engine..
Old 08-15-2006, 02:40 AM   #13
BringItOn's Avatar
if you want a pinch i can do it for you. just pay for postage. i have done it for my friends.
disclaimer: all care but no responsibility taken
BringItOn is offline   Reply With Quote
Old 08-15-2006, 07:59 AM   #14
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
I have a few pinchers myself and have probly pinched 2 or 3 dozen engines . If you get a good quality pincher it works out great . I get about another 4-5 gallons per pinch . I`ve only pinched the same engine twice and wouldn`t go beyond that . These myths of cheap ways and hose clamps to pinch are a waste as you will oval the sleeve . As long as the rod is still in good shape it`s safe to pinch . But do your first few pinches on some junk engines as it can be easy to overpinch .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Pinching of the engine tkhoo Offroad Nitro Engine Forum 43 05-11-2012 03:57 PM
sleeve pinching? scurran Onroad Nitro Engine Zone 43 08-30-2010 06:00 AM
Nitro engine service, pinching, bearing replacement 22Racer R/C Items: For Sale/Trade 3 09-07-2008 08:41 PM
pinching a buggy engine playzwtrux Nitro Off-Road 4 03-17-2008 08:45 AM
Rebuilding vs Pinching vs New CRASH Nitro Off-Road 1 09-09-2007 09:24 AM
