Old 08-13-2006, 05:30 PM   #1
Default Easiest way to remove the flywheel from nitro engine?
What is the easiest/best way to remove the flywheel from a nitro engine? They are really hard to pull off after they have been secured with the flywheel nut. I have read that it is best to use an automotive battery terminal pulling tool, but I don't have one of those. Is there an easy way to remove it without introducing undue stress to the motor shaft and flywheel? Thanks in advance for your help. I am totally new to nitro, so I am a bit clueless.
mekong56 is offline   Reply With Quote
Old 08-13-2006, 06:06 PM   #2
Trader Rating: 39 (100%+)
A battery terminal puller will work, but I find that the one I have is a bit flimsy and cheap.
I have this and it works well:
http://www.amainhobbies.com/product_...oducts_id/4098
Chuck
www.ridgewaybodies.com
https://www.facebook.com/ridgewaybodiesRC/?ref=hl
ridgewaybodies is offline   Reply With Quote
Old 08-13-2006, 06:15 PM   #3
subarubie's Avatar
The terminal puller is your best bet on removing the flywheel with out damaging anything....It is a good investment as you will use it again.
subarubie is offline   Reply With Quote
Old 08-13-2006, 06:18 PM   #4
Remove the nut and then gently tap the back of the flywheel a few times in a few places with a small hammer. It should just pop off.
Do not take a big swing at it, just a few gentle taps is usually all that's needed.
AreCee is offline   Reply With Quote
Old 08-13-2006, 07:16 PM   #5
SpeedBump57's Avatar
Flywheel puller!!! It will be the best 36 bucks you ever spent.......
SpeedBump57 is offline   Reply With Quote
Old 08-13-2006, 07:42 PM   #6
xlgraphicspro's Avatar
I use two large flat blade screw drivers, place one on each side underneath the fly wheel, and without much pressure at all it pops off! No damage to either flywheel or engine!
The best part, everyone has atleast 2 flat blade screw drivers. if your concerned, you can wrap the screw driver tips with paper towels.
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Old 08-13-2006, 08:01 PM   #7
Trader Rating: 14 (100%+)
the battery terminal puller is the best, you can get cheap ones at harbor freight.
o.s. power is offline   Reply With Quote
Old 08-13-2006, 10:12 PM   #8
Your local auto parts store has terminal pullers for like $5 and much much safer than a screwdriver. If you are like me and hate anything marred, gouged or disformed, you will definitely appreciate a quality flywheel puller!
Chuck
Old 08-14-2006, 12:56 AM   #9
KK-racing's Avatar
Do 'IT', with a DUREX (safely) !!!
KK-racing is offline   Reply With Quote
Old 08-14-2006, 01:09 AM   #10
KK-racing's Avatar
Well, I learnt the easiest new way yesterday at our track.
There was this buddy running an O.S. V-spec in his MBX5 for about 2 races already, not to count the 6 ~7 weekends of practices in between. Then suddenly his engine keeps shutting off after landing from jumps for no apparent reason. A check showed the flywheel has kind of moved back & sticks itself to the engine front bearing with aluminium burr around it. Everyone started crowding around straining their necks to get a better view when he starts dismantling the clutch-bell, shoes & flywheel to see what causes that. Out comes the clutch-bell retaining screw, next the bell & then the shoes.
Finally the flywheel locking nut was taken out &........ he literally just lifted the flywheel out without any effort, not to mention any tools. Then people start guessing - 'the conical bushing got smashed to bits', 'no, no, it was worn off to thin air'. Then our smart buddy, blushing all red open his tools box & took out the conical bushing....'I forgot to put it in' !. Now isn't this the easiest method to remove the flywheel ?. Joke(the incident is true though) aside, I used the tapping method with a aluminium rod behind the flywheel, for years without any problem.
Old 08-14-2006, 08:08 AM   #11
Or you can make your own!
Here is one I made from a tractor trailer shock mount. By looking at the top of the puller you can see where I cut it from the shock shaft. It took about an hour to make and the cost was nothing. It works very well.
How do you remove flywheel? deskwarmer Nitro Off-Road 9 05-22-2008 08:28 AM
how do you remove a flywheel from a nitro engine TeamFast Rookie Zone 6 04-26-2008 11:47 PM
HOW DO I REMOVE A FLYWHEEL??? HELP PLZ paul73rc Nitro On-Road 15 06-23-2007 08:33 AM
how to remove nut that attached to flywheel?? bigboss Nitro On-Road 11 10-03-2006 08:42 PM
how do i remove my flywheel? downunder23 Nitro On-Road 5 08-26-2006 04:18 PM
