Old 08-10-2006, 07:39 AM   #1
Scarab's Avatar
Exclamation O.S. VZ-B V-Spec T w/ O'Donnell Head - New Button???
I was told to use the button (and glowplug) from the VZ-B V-Spec T with my new O'Donnell head. However, the head does not properly fit the stock VZ-B button. Is there another button I can use? Does O'Donnell plan on making a specific button for the turbo VZ-B? Please help if you have any information.
Scarab
Team Monkey Spankers (TMS)
Losi Ten-SCTE 2.0
Jammin SCRT 10
Mugen MBX5-T ProSpec - O.S. .28 XZ [b]FOR SALE![/b]
Traxxas Revo - O.S. .18 TM [b]FOR SALE![/b]
Scarab is offline   Reply With Quote
Old 08-10-2006, 10:07 AM   #2
Trader Rating: 14 (100%+)
i believe that the o'donnell head does come with a new button that still utilizes the turbo plugs.
o.s. power is offline   Reply With Quote
Old 08-10-2006, 12:00 PM   #3
Scarab's Avatar
No, it comes with a standard button and a standard glow plug.
Scarab
Losi Ten-SCTE 2.0
Jammin SCRT 10
Old 08-10-2006, 03:27 PM   #4
ok, I see your predicament now.
Old 08-10-2006, 07:19 PM   #5
hyper7vspec's Avatar
Send a message via MSN to hyper7vspec
i have an odonnell head on my v-spec.i used the vspec button and used shorter cap head screws to screw the head on.the standard ones are too long with the odonnell head
-Andrew Foord- Thanks to all of my sponsors!
TLR - OMP/Modelflight - Orion - Proline - Nitrolux Fuel - Savox - HobbyWing - RCRS.com.au - Schelle - NVision - Ace Hobbies
hyper7vspec is offline   Reply With Quote
Old 08-10-2006, 07:57 PM   #6
Scarab's Avatar
I talked to Steve O'Donnell himself today and he told me that they have test the VZ-B V-Spec with the O'Donnell button that comes with the head and the standard plug and it runs the same with no performance loss. So, I'm going to try it.
Scarab
Losi Ten-SCTE 2.0
Jammin SCRT 10
Old 09-25-2008, 07:58 AM   #7
Smile Same Problem...More Info
I recently had the same problem. The O'Donnell instructions are somewhat ambiguous. First, yes the stock screws are too long. The directions say for one particular O.S. engine (not the V-Spec), use the enclosed screws and for all other models use the stock screws. Well the package does not come with "any" screws and you either have to cut off about 1/8" from the stock screws (Dremel tool works well) or get different screws.
Second, if you use the O'Donnell button then you have to use the O'Donnell 99 standard plug (or comparable). On the other hand if you use the stock V-Spec button then you can use the O'Donnell 97T turbo plug (or comparable). The instructions say to use the O'Donnell 97T plug, but it never tells you to use the stock button. Quite confusing until you think about it and remember that the threads are different.
After speaking to more than one person from their Tech Support (because each of them gave a different answer) I finally determined that you can use whatever you like. O’Donnell button with standard plug or stock V-Speck button with turbo plug. If you use the stock button the total diameter is smaller than the cut out in the bottom of the head, but just line up the screw holes and it works fine. Make sure you use the O.S. copper gasket. (I purchased a new one to be safe).
I have a Mugen MBX5R with the O.S. V-Spec that is about 2 years old. I put the new head on with the stock button and it screams down the track with no adjusting. Hope this clears up any confusion. One of O'Donnell's people did say that it appears the instructions have some issues. Hopefully they will revise it.
Want To Save Gas? Drive An RC Car!
MBX5R (2), Savage XL, Associated B4, Airtronics M12
NOIC is offline   Reply With Quote
o'donnell novarossi head, nova go tech .21 head,misc air filter thebert686 R/C Items: For Sale/Trade 20 01-08-2008 12:27 PM
V-SPEC Head and button on a VG ? shockripple Nitro Off-Road 3 12-06-2007 03:59 AM
.21 O'DONNELL BLACK V-SPEC HEAD NIP KEITH R/C Items: For Sale/Trade 0 01-21-2007 09:40 PM
O.S. VZ-B V-Spec T w/ O'Donnell head - New button??? Scarab Onroad Nitro Engine Zone 1 08-10-2006 07:28 PM
FOR SALE O'Donnell .21 Novarossi P5/O.S. V-Spec (4 bolt) Cooling Head Matthew.H R/C Items: For Sale/Trade 0 07-12-2006 09:28 AM
