Old 08-10-2006, 12:51 AM   #1
Default rc10gt engine mounting Q
Hey, I wanted to install an OS CV-R .15 (standard shaft) on a GPM double deck rc10gt chassis. I was wondering if the shaft would need to be cut, if so would it also need to be rethreaded, and second would it be possible to just mount the engine further back or would there not be enough space to mount it as far back as required. Thanks.
NiTeHaWk4787 is offline   Reply With Quote
Old 08-10-2006, 10:10 AM   #2
Trader Rating: 14 (100%+)
you would have to cut the crank. In order to do this, you have to put on the collet and flywheel. There is a special nut that associated has that you thread onto the crank and run the dremel right next to that to get the correct amount of crank. When you take that off, it will clean up the threads so you won't have to worry about re-threading or anything like that.
o.s. power is offline   Reply With Quote
Old 08-10-2006, 11:17 AM   #3
Associated Nut
Is that the nut you're talking about? It says its for .12 engines but I'm not sure if it would work on a .15 engine. The .12 and .15 OS series use the same exact crankcase so that's why i'm wondering. And would I have to get a certain flywheel and clutch assembly or is the HPI setup i'm using okay? I'm just wondering because the HPI flywheel has a raised lip area seen here
HPI Flywheel
and I just want to be sure that it will leave enough space on the shaft. If the HPI one is fine, would I have to get a new collet?
Old 08-10-2006, 02:28 PM   #4
Stuff
This looks like everything I would need actually, seems it would work with the OS. The only thing missing are clutch springs.
Old 08-10-2006, 03:24 PM   #5
the first link you posted is what you put on the crankshaft after you have cut the crank.
The second link of the hpi flywheel is a no no. Stick with the associated flywheel.
the third link has everything you need, that little black nut you see is what you put on the crank as a cutting guide. I believe the associated 2 shoe clutch does not use speings. Go with the MIP 4n1, no brainer to setup and works really good, and cheap too.
Old 08-10-2006, 03:42 PM   #6
MIP
Yea I was actually looking at that earlier today as an alternative. I'll go with it then since you recommended it. It looks 50x easier than using stupid clutch pins also heh.
Old 08-10-2006, 06:44 PM   #7
with the associated flywheel though, you will have to take a hammer and beat the pins back a little bit, its not hard to do, just make sure you do it.
Old 08-10-2006, 08:15 PM   #8
amain's Avatar
if ur using the hpi set up you dont have to cut nething the threads are fine as that "raisd lip" get rid of the clearince issues
amain is offline   Reply With Quote
%%%% RC8 FT Engine Mount and 2 Engine Mounting Plates jf45 R/C Items: For Sale/Trade 0 05-12-2008 04:56 PM
Engine mounting screw catkchun Malaysian R/C Racers 28 10-19-2007 07:31 AM
engine mounting problem krnfx Nitro On-Road 2 07-14-2006 06:34 AM
RC10GT Engine mounting Ryan C. Electric Off-Road 10 12-18-2005 04:00 PM
mounting new engine? wlvrn Electric Off-Road 23 07-19-2005 07:34 AM
