Old 08-08-2006, 02:14 AM   #16
itchy b's Avatar
Originally Posted by Turbo Joe
Wow.
I can smell that from here.
there's a good case for the nitro is safer brigade!
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 08-08-2006, 08:08 AM   #17
Rick Hohwart's Avatar
What kind of insulation was used to prevent battery to graphite contact? Perhaps it was worn through?
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 08-08-2006, 08:41 AM   #18
DR VOODOO's Avatar
R/C Tech Charter Subscriber
BEEN THERE DONE THAT
DR VOODOO is offline   Reply With Quote
Old 08-08-2006, 09:47 AM   #19
Crim3Wav3's Avatar
not to mention the Fusion battery bars are scary....you are just asking for a short with those stupid (and pointless) heatsinks.
Crim3Wav3 is offline   Reply With Quote
Old 08-08-2006, 10:27 AM   #20
Buckyaga's Avatar
the pack only had 4 runs on it. Its possible that the shrink wrap wore through that fast.
I think those evil EVIL battery bars had something to do with it
Buckyaga is offline   Reply With Quote
Old 08-08-2006, 10:30 AM   #21
Z_Schneider's Avatar
Thats the best excuse Ive ever seen to get a new car...
~X-ray 808-'10~X-ray XT8-'09~Associated SC10~Kyosho RB5
Sponsors:
~JConcepts~CPR Adrenaline~Shellz custom painting(me)~Team Dirtheaven~
Z_Schneider is offline   Reply With Quote
Old 08-08-2006, 10:45 AM   #22
Buckyaga's Avatar
hmm.. I think you are on to something
Old 08-08-2006, 11:42 AM   #23
Quinn Konitzer's Avatar
ouch good luck fixing it up
-Dirt Heaven-
-White Knuckle RC-
-Victory Hobbies-
-Team Associated-
Quinn Konitzer is offline   Reply With Quote
Old 08-08-2006, 11:57 AM   #24
Trader Rating: 26 (100%+)
he means bewteen the chaisis and the ends of the cell, where the battery bars are, those can't come in contact with the graphite, Losi kits come with a clear sticker thing that you put on inside the tub, Persoanlly I put a layer of electrical tape,
bobf24 is offline   Reply With Quote
Old 08-08-2006, 12:34 PM   #25
Even this insulator can wear over time and if your positive and negative bars touch the chassis, your battery will short out and burn up.
I only mention it because I could not see any insulators. Maybe they can't be seen, or they were burned away. But not using them will cause the problem you experienced.
www.reedypower.com
Old 08-08-2006, 12:39 PM   #26
Rick- Would that really cause it to blow up? I thought it would only cause the cells to vent.
Kyosho / Team Orion / AKA / JTP / Sharkbait Designworks / RC Tracks of Las Vegas
Chris Jarosz is offline   Reply With Quote
Old 08-08-2006, 12:51 PM   #27
Cells will vent to release pressure build up, especially during charging. They during discharge as well.
But if the + and - leads touched the graphite chassis at the same time for an extended period, and the pack had a decent amount of charge remaining, it would be just like soldering the leads together. The pack may vent initially, but the short circuit would continue until the connection (battery bar, chassis contact, internal cell construction) was broken.
This may or may not have happened. But if I had been presented with this warranty claim, the first thing I would ask is "was the chassis insulated?"
www.reedypower.com
Old 08-08-2006, 01:29 PM   #28
Iceracer's Avatar
I applied 7.2 volts from a charged IB3800 pack to an uninsulated graphite MF2 chassis and could only measure 300ma of current flow. While I do have my chassis insulated with tape, it does not appear that on my Losi chassis, enough current could flow to cause anythign other than a slow discharge.
Perhaps the surface conductivity of the chassis can change over time as oxidation occurs, but on a couple year old chassis that I tested, conductivity was poor.
Anyone else want to try?
Iceracer is offline   Reply With Quote
Old 08-08-2006, 02:20 PM   #29
Iceracer's Avatar
Two leads from a digital ohmeter, on the chassis one inch apart. If I really dig them into the chassis, I can get 500 ohms of resistance as a minimum. Unless my MF2 doesn't really have a graphite chassis (despite the words Graphite XXX on the bottom ), the odds of a battery short against it causing any significant current flow appear non-existant.
Don't get me wrong, I'm not claiming to be an authority, but aside from a slow current drain and probably radio noise from the shorting, it doesn't look like a graphite /plastic Losi MF2 chassis can conduct fire starting, battery popping current. Perhaps the strands in a carbon fibre sheet are another story, but that wasnt the chassis material shown here.
Old 08-08-2006, 08:40 PM   #30
Swanny's Avatar
I think I can see remnatts of the insultion in some of the pictures, so possibly the answer is yes to Rick's question.
XRay T2'009 - Sanwa MT-4 - Futaba BLS551 - Tekin RS - Trinity 13.5
http://www.facebook.com/radioracingcarssa
Swanny is offline   Reply With Quote
