Old 08-07-2006, 08:43 AM   #1
NotEZ2Beat's Avatar
Default Can't get XR2i to work with ESC
I have an JR XR2i radio that I pulled out of and XXX-T RTR II Kit and one of the ESCs that come in the kit. It is made by Novak for Losi. I can't get the radio to control the ESC. Maybe the ESC is bad, I am not sure. I tried reading all of the instructions but still can't get it to work. Is there some trick I am not aware of?
NotEZ2Beat is offline   Reply With Quote
Old 08-07-2006, 10:47 AM   #2
pull-start's Avatar
Trader Rating: 27 (100%+)
Here are a few things to check:
Are you using the correct receiver?
Are your crystals in securely?
Do you have the ESC and servo in the correct channels on the receiver?
Hope that helps...
pull-start is offline   Reply With Quote
Old 08-07-2006, 11:59 AM   #3
NotEZ2Beat's Avatar
thanks pull-start. I have done all of those things and followed the instructions closely. Has anyone set up these two before? Did you have any issues with them.
Old 08-07-2006, 12:39 PM   #4
I have had trouble with getting Novaks to work, try turning up your throttle exponential if you can, this should help the ESC pick up your radio.
HTH
Rod
gatermaxx is offline   Reply With Quote
Old 08-07-2006, 12:42 PM   #5
Trader Rating: 114 (100%+)
Send a message via AIM to Valentin.H
does the radio work with other escs? does the esc work with other radios? you might wanna check that..and if one or both is bad...id probably call novak and jr and see whats up
-valentin
www.csjunkies.com
Valentin.H is offline   Reply With Quote
Old 08-07-2006, 01:24 PM   #6
HTH
Rod
I forgot to mention doing this for binding the radio/esc
Rod
How do starter boxes work? Do they work with Shaft Start engines? Ofna_Driver_777 Electric Off-Road 7 02-25-2007 07:51 PM
XR2i 27mhz for a XR2i 75mhz. viper15 R/C Items: For Sale/Trade 3 12-12-2005 10:42 AM
JR XR2i SavageSYNTH25 R/C Items: For Sale/Trade 0 11-19-2005 08:57 PM
JR xr2i am 27 $30 ROLLINGaFTGT R/C Items: For Sale/Trade 2 10-06-2003 01:13 AM
jr xr2i f/s f/t rcdude49 R/C Items: For Sale/Trade 3 07-27-2003 12:15 AM
