Old 08-06-2006, 06:49 AM   #1
gman10's Avatar
Default Tires?
Need to get somebody's input on tire choice. Ran yesterday on a hardpacked out door track that had a thin layer of sand on top. I ran 1/10 scale electric truck. I tried bow ties, evil twins, hole shots, and T-2000, none of them seemed to work. Any suggestions?
gman10 is offline   Reply With Quote
Old 08-06-2006, 07:45 AM   #2
schmelme's Avatar
i assume it was hard packed dirt not clay or black dirt. I would probably run the holeshots when its swept off or try some Ifmar pins when its dusty. the ifmar pins have enough pin the get through the loose top without folding over. good luck
schmelme is offline   Reply With Quote
Old 08-06-2006, 09:32 AM   #3
Alex Forrest's Avatar
Send a message via AIM to Alex Forrest
I would have to say try IFMAR pins like Karl said.
Alex Forrest is offline   Reply With Quote
Old 08-07-2006, 02:44 AM   #4
B4Bandit's Avatar
Yeah, IFMAR Pins are good but I would also check out Losi Bigshots... They have better side roll support I reckon.
I think red X-2000's are some of the best though.
B4Bandit is offline   Reply With Quote
Old 08-07-2006, 01:36 PM   #5
santinuchi's Avatar
Default me
i'd suggest ifmar's as well, i run on a track that fit's the description of your track.
santinuchi is offline   Reply With Quote
Old 08-07-2006, 01:40 PM   #6
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
i think he is running truck..
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 08-07-2006, 01:44 PM   #7
RaceAce701's Avatar
Trader Rating: 86 (99%+)
I run ifmar pins on my truck and wont run any thing else the are great.
Our track is close to wat u described.
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 08-07-2006, 03:04 PM   #8
gman10's Avatar
Thanks for the suggestions. It seems Ifmar pins are what I need to get.
Old 08-07-2006, 06:11 PM   #9
dirtracer1's Avatar
if you can still find any, pro-line fuzzie t's usually worked even better than the ifmar's. you might be able to find a couple of pairs on ebay.
Losi 22
Losi 810-e
Losi SCTE
Losi XXX-MF2/CRC SC
B&T R/C - http://b-treman-rc.valp.net/btrchome.htm
dirtracer1 is offline   Reply With Quote
Old 08-10-2006, 08:03 PM   #10
djssafeseat's Avatar
The Ifmars are awesome. Thanks for the help. Its amazing what the difference from tire to tire are. They helped alot.
djssafeseat is offline   Reply With Quote
Old 02-23-2007, 02:56 PM   #11
I got a question too.....the track I'm racing on is a bit of everything really we got the really packed stuff with loose dirt on top (some bits are really fine).
It's a pritty bumpy track on some bits too (around corners, it seems that cars have been taking chunks off the track).
I have tries bowties....horrible....sideways everywhere.
knobby studs.......even worse....just no traction.....anywhere on the track.
snake eyes......the best I found yet....pritty consistant. I want to try gladiator 2. do you guys think this will work?
I havent ttries the really fine tires yet eg. (fuzzy Ts)
any sugestions would be helpfull.
zheng0416288390 is offline   Reply With Quote
Old 02-23-2007, 05:41 PM   #12
gubbs3's Avatar
Gladiator's are a harder compound (M2 I believe) and work worse than about any other "race" tire. Snake eyes do work pretty well on tracks that have a really broken up or uneven surface and a variety of loose and hard sections. But Ifmar pins are still the king on anything that is somewhat hard that doesn't groove up.
gubbs3 is offline   Reply With Quote
Old 02-23-2007, 05:57 PM   #13
I dont know exactly what you mean by groove up.
Old 02-23-2007, 10:58 PM   #14
dirtracer1's Avatar
he means blue groove......that means that a layer of rubber is laid down on the veeeeery hard packed dirt after many runs and you'll be able to see a dark racing line develope on the track.
when all else fails.....use the tire that will work on any track, anywhere, in any conditions.....step pins. you can get a step pin in several different compounds from several different companies including pro-line, team losi or panther.
Losi 22
Losi 810-e
Losi SCTE
Losi XXX-MF2/CRC SC
Old 02-23-2007, 11:53 PM   #15
IC well I think I will stick with the snake eyes. as I dont have blue groove track.
Cleaning Out Garage Sale TIRES TIRES TIRES MattOCM R/C Items: For Sale/Trade 5 01-15-2008 03:55 PM
Foam Tires, Parma, TRC, JACO, Tire truer, Rubbers tires and much much more! Team Speedy R/C Items: For Sale/Trade 43 12-15-2006 10:38 AM
Team Orion tires / monster truck tires and weld wheels evostyle R/C Items: For Sale/Trade 4 04-25-2006 09:52 PM
TIRES tires TIres, Ellegi or UFRA. bleach1 Nitro On-Road 51 06-01-2004 10:58 PM
Used trc & jaco touring & 12th scale tires trued mint shape a ton of tires 1 to 3 run jason cheng R/C Items: For Sale/Trade 10 01-02-2004 10:27 AM
