Old 08-03-2006, 03:50 PM   #1
fordman86's Avatar
Trader Rating: 32 (100%+)
Default RX pack charging help
I want to charge my 2500 rx pack with a .8A wall charger what is the formula to figure out the time to leave it on the charger.
fordman86 is offline   Reply With Quote
Old 08-03-2006, 04:10 PM   #2
Scottmisfits's Avatar
1 amp charge rate takes 1 hour to charge 1 amp.
2500mAh/800mAh= just over 3 hours.
Scottmisfits is offline   Reply With Quote
Old 08-03-2006, 04:18 PM   #3
fordman86's Avatar
cool thanks
Old 08-04-2006, 06:08 AM   #4
SpeedBump57's Avatar
Although Scott's formula is correct make sure you discharge your pack first if you use it or you might over heat them leaving them on for 3 hours.
SpeedBump57 is offline   Reply With Quote
Tx pack charging help Allumina Radio and Electronics 7 08-08-2008 08:10 PM
Charging 3pk battery pack (8 cell 2400mah Venom NIMH pack) mcgmark Electric On-Road 2 11-06-2006 08:57 AM
Reciever pack charging IronTusk Electric Off-Road 11 04-12-2006 06:24 PM
NiMH Rx and Tx pack charging performula Nitro On-Road 9 05-16-2005 11:01 AM
receiver pack charging RebelRacer Electric Off-Road 6 08-07-2004 05:47 PM
