Old 08-02-2006, 12:36 PM   #1
pumpkinfish's Avatar
Default Which .12 engine for 1/10 gas truck?
I am torn between the OS .12 TZ or the Novarossi Top TN12R2. Which is better for fuel economy and has more low end grunt? I will be pairing these up with an Adam Drake pipe.
Thanks!
Yokomo YZ-2, B-Max4 III
Kyosho RT6
Losi 22b, XX4 Worlds
Associated SC10.2, RC10B2, RC10T2, RC10
pumpkinfish is offline   Reply With Quote
Old 08-02-2006, 12:41 PM   #2
Trader Rating: 14 (100%+)
scrap both and get the nova CX12 RN2.
the TZ is too powerful for gas truck, strictly an on road engine.
o.s. power is offline   Reply With Quote
Old 08-02-2006, 01:23 PM   #3
Trader Rating: 26 (100%+)
i like the OS 12 CVR, they have a great power band for offroad, and are really good on gas, and really well priced, they arn't the fastest motor out there by any means, but they are really nice and smooth,
bobf24 is offline   Reply With Quote
Old 08-02-2006, 03:00 PM   #4
Is it for bashing or racing?
If it's for racing then I agree with bobf24 about the OS CVR.
If it's for bashing then get the most powerful engine you can find.
(I use a '03 Fantom FR12R in my Losi XXX-NT and it is one one the quickest trucks on the track because the powerband allows the rear wheels to hook up without spinning. Our fastest racer uses the old OS CV in his GT.)
AreCee is offline   Reply With Quote
Old 08-02-2006, 03:59 PM   #5
dirtracer1's Avatar
that's what i use......just a plain 'ol os cv. the cheapest motor they make. i just take off that cast head and put a good head on it. it's easy to tune, holds a tune and is waaaaay more than enough power for local racing. it'll pull the front end off the ground on a regular basis. paired up with an os t-1030 pipe and it's a rocket. here's mine.......
Which .12 engine for 1/10 gas truck?-100_2666.1.jpg
Losi 22
Losi 810-e
Losi SCTE
Losi XXX-MF2/CRC SC
B&T R/C - http://b-treman-rc.valp.net/btrchome.htm
dirtracer1 is offline   Reply With Quote
Old 08-02-2006, 04:53 PM   #6
Sorry I should have said I'll be racing only.
I had the Mugen MT12 that came with my truck and that lasted a looong time...lol! When that wore out all the guys at my track swore by the Dynamite .12 spd so I gave in due to how cheap it was. It lasted about a month!?! So I want to go back to something more reliable.
I have an O'Donnell cooling head that is in an Associated AE 12x Cylinder Head P/N 29090 bag. Will this fit the OS CV?
Kyosho RT6
Old 08-02-2006, 06:39 PM   #7
dirtracer1's Avatar
i'm not totally sure, but i think it will. however, i use a King Headz head....part number KH-060.
http://www.kingheadz.com
if os rocket made heads for .12's, i'd buy one of those in a second....but they just make heads for .21's only (as far as i know). i use an os rocket head on my os vzb v-spec.
also....nitrohouse.com has THE o'donnell heads for the os .12 in purple color. scroll down to the bottom of the page. they're only 15.95 each.
http://www.nitrohouse.com/blowout_specials.htm
Losi 22
Losi 810-e
Losi SCTE
Losi XXX-MF2/CRC SC
Old 08-02-2006, 07:37 PM   #8
sport10's Avatar
The Novarossi will give you the same reliability and longetivity as the MT12 you had. Also, you were not able to repinch the cylinder or get a replacement cylinder and piston to revive the MT12?
Hot Bodies VE8 w/ RX8-1900 combo
Associated B44
Associated B6
Associated TC7.1
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 08-02-2006, 07:55 PM   #9
Trader Rating: 28 (100%+)
Get the nova, they are awesome as you know since you had an mt .12!!
RayAracing just pinched my mt .12 for me, he does AWESOME work.
jbrow1 is offline   Reply With Quote
Old 08-02-2006, 08:51 PM   #10
Send a message via AIM to RCjunky22
go with the Orion wasp .12 drone
Kyosho ST-RR(soon!!!)
King Headz chassis braces
RB Modded S7 with Dynamite Platinum 007
Kyosho 777SP2 WC-
Hitec servos, Modded RG looking for a good pipe
RCjunky22 is offline   Reply With Quote
Old 08-03-2006, 06:05 AM   #11
just go with os cvr rotary carb. I looked at several motors, i even found a brand new in the shrinkwrap mt12. I may give a little up on the straightaway but motor has tons of torque and run really well. I had a os tr that was just a real handful and i had issues.
DAVE BERNATH is offline   Reply With Quote
Old 08-03-2006, 08:00 AM   #12
Isn't that the engine you have to gear to the moon before you see the performance it's supposed to put out???
Old 08-03-2006, 08:58 AM   #13
I am using the stk gearing for the drake 2, i also 3/4 of a once in the front bulkhead to help keep the front end down and gain some steering. the motor is perfect for stadium. the tracks we race on are getting blown out due to the the other class's. major HP is wasted. i considered on getting another CVR and have it worked over for the bigger tracks.
Old 08-03-2006, 09:11 AM   #14
Jack Smash's Avatar
Trader Rating: 29 (100%+)
I'm using a TZ in my truck and it is a bit overpowered, gotta be real smooth with the trigger and make sure to put the front wheels back on the ground before hitting the face of the jump.
Anyone know when to get carb restrictors for the rotary carb TZ?
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 08-03-2006, 09:48 AM   #15
JLock's Avatar
You best bets will be either the OS 12cvr or the new OS 12tg. The new OS 12tg looked to be designed for offroad use in stadium trucks, giving you more controllable power for 2wd trucks than the OS 12tz. One of the best engines for this purpose was the Mugen MT12, but it was discontinued a couple of years ago.
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
monster truck engine bigemike Nitro Off-Road 3 05-09-2008 01:08 PM
selling custom savage roller with engine, truck zillia modded engine.$275 pat360xboxhalo3 R/C Items: For Sale/Trade 2 01-11-2007 05:23 AM
NEED MONSTER TRUCK ENGINE!!!!!!!! REVO MAN R/C Items: Wanted to Buy 10 01-10-2007 09:16 PM
WTB: Monster Truck Engine i_like_f150s R/C Items: Wanted to Buy 7 12-22-2005 12:45 PM
Associated GT Truck with O.S. TR Engine madness R/C Items: For Sale/Trade 0 05-19-2004 07:47 PM
