Old 07-25-2006, 10:49 PM   #1
Send a message via AIM to oMONSTERo Send a message via Yahoo to oMONSTERo
Default One cell hotter than others in pack
This is a fairly new pack. 3300 Powerizer. Why is this happening?
oMONSTERo is offline   Reply With Quote
Old 07-25-2006, 10:58 PM   #2
Trader Rating: 114 (100%+)
Send a message via AIM to Valentin.H
is this pack matched? i doubt it..powerizer is that one cheapo company..anyway
the most sensible thing that comes to my mind is probably the other cells are dumping faster than that particular cell, and alot of the battery's juice is being sucked out..causing it to heat up...i could be wrong..im not sure
or that one cell is going bad...
either one of those..
-valentin
www.csjunkies.com
Valentin.H is offline   Reply With Quote
Old 07-25-2006, 11:11 PM   #3
sounds like one of the cells is being over charged ... or under discharged as the other cells capicity is diffrent from that one .. try discharging the pak then use an equalizing tray after the pak sits for a while ... this should help with keeping the cells even throught cycles ...
Mark Barden .
mb racer is offline   Reply With Quote
Old 07-25-2006, 11:13 PM   #4
Default Oh yeah
This is happening when charging. I havent taken notice of what happens when running it, yet.
Old 07-25-2006, 11:24 PM   #5
RCBLUE's Avatar
Like it was said earlier try to use a tray before you recharge your pack. If it still gets hot after using the tray properly then I would suspect that cel to have a high internal resistance which generally means that the cel sucks or is going bad. I recommend the zero 30 tray from Integy. I use one regularly and my pack are always great.
Don't sweat the petty things...........Pet the sweaty things!!
Serpent America
Lunsford Racing
RCBLUE is offline   Reply With Quote
Old 07-25-2006, 11:35 PM   #6
Bit_Rusty's Avatar
Battery bars/connections between the cells all ok??
Bit_Rusty is offline   Reply With Quote
Old 08-06-2006, 08:53 PM   #7
Default wow
Today it took THREE charges to get approx 1600 mah in this batt., and it was HOT. I ran it, and it ran pretty good/long. BUT, when I took it out, it had actually MELTED THE SHRINK WRAP ! ! ! ! Only around THAT particular battery though. Guess it will be retired until a "battery rebuilding day".
Old 08-06-2006, 09:33 PM   #8
BringItOn's Avatar
IF 1 CELL IS hotter than the others means that, that cell has a higher internal resistance than the others. its prob been overcharging.
BringItOn is offline   Reply With Quote
IB 4200 6 Cell Pack Nice Pack Good Numbers 27.00 Shipped rcdreamer95 R/C Items: For Sale/Trade 0 03-02-2008 12:55 PM
Charging 3pk battery pack (8 cell 2400mah Venom NIMH pack) mcgmark Electric On-Road 2 11-06-2006 08:57 AM
How can I charge an 8 cell pack with a 7 cell charger? Artificial-I Electric On-Road 15 01-24-2005 01:15 AM
5 cell receiver pack kits for $15! 6 cell 2/A packs starting at $15! torchedlh R/C Items: For Sale/Trade 0 03-25-2003 10:49 PM
