Quick question about 1/8 scale buggy engine. >
Old 07-24-2006, 09:55 PM
Swede#1's Avatar
Default Quick question about 1/8 scale buggy engine.
So, im getting a Sportwerks Mayhem buggy, but what engine should i get ? now, i dont want to spend a fortune, i just want something " cheap " and what size should i get ? is there any limitations on engines for racing or can i get any size ? with size i mean like .21 .26 .28 and so on. How about the STS .28 ?
Thanks.
Oohh, i forgot, im using the stock pipe, atleast for now.
Swede#1 is offline
Old 07-24-2006, 10:29 PM
WheelNut's Avatar
For racing the limit is .21ci/3.5cc, no more than that. If your new to racing or totally new to offroad pick up something like the OS 21RG, its inexpensive and doesn't have enough power to be a big handful on the track.
WheelNut is offline
Old 07-24-2006, 11:45 PM
SpeedBump57's Avatar
Take that advice ^^ and run!!
SpeedBump57 is offline
Old 07-25-2006, 08:00 AM
Hey Berndt,
My opinion is that you would never want to put anything more than a .21 in a buggy. Their already hard to control as it is b/c they have so much power. The OS RG is probably the best inexpensive motor out there and very smooth. Not a ton of top end but you could get someone to modify it when you decide if you want more power. I think you will like it. I too an getting an 8 scale this year, but I am waiting for the LOSI rig to come out. I may even seel my REVO
riverrevo is offline
Old 07-25-2006, 08:10 AM
SkarTisu's Avatar
+1 on the OS RG engine. I just started racing gas this year, and that motor has been pretty forgiving on carb tuning so I've been able to learn some stuff about engine tuning.
When tuned properly, those motors are faster than people think. I've been able to stay with engines that are two to three times as expensive on long straightaways, and have been able to clear every jump section that everyone else has.
SkarTisu is offline
Old 07-25-2006, 08:49 AM
Tabushi's Avatar
Thanks.
Just buy an STS .21B engine and be happy flying around the track ... if you need one, call Ryan at www.racernine.com ...
cya !
Tabushi is offline
Old 07-25-2006, 11:22 AM
i have a os 21 rg bump start motor it has more then enough power to poll away from the pack .... so i would say get that motor...
rc pro is offline
Old 07-25-2006, 03:13 PM
Trader Rating: 26 (96%+)
Get your self an o.s. rg and a bump start. It will make your day at the track much more enjoyable. The o.s. rg will go toe to toe with most engines up at about 90 ft. and then a 300 power plant will pull away. However, you aren't going to notice this untill you have at least a good season of driving under your belt.
party_wagon is offline
Old 07-25-2006, 03:19 PM
BuckMan's Avatar
RG=Really good!!
BuckMan is offline
Old 07-25-2006, 04:41 PM
Swede#1's Avatar
Hhhmm, it seems like the os Rg is popular I read here : http://www.amainhobbies.com/product_...oducts_id/6122 That the engine runs hot with the stock head, is that anything you have noticed ?
Thanks for all your help guys !!
Swede#1 is offline
Old 07-25-2006, 09:21 PM
SkarTisu's Avatar
Yes, I have noticed that. My engine doesn't put out good power until it's tuned to run 260 degrees F or higher. This temperature doesn't seem to harm the engine either. Two gallons through mine so far, and I still have good pinch. I've had a few runs where it came off the track at over 300 degrees as well, and I didn't hurt it doing that, either.
One thing to make sure you do if you buy this engine is to get the exhaust manifold gasket as well. They don't come with the gasket from the factory, and it's necessary to completely seal the exhaust manifold so you get consistent performance.
SkarTisu is offline
Old 07-25-2006, 09:42 PM
TKO
TKO's Avatar
The NOVA or King Headz option heads will drop the running temperature around 30-40 degrees. The RG's really seem to like a Jammin JP-1 pipe as well.
TKO is offline
Old 07-25-2006, 10:01 PM
SkarTisu's Avatar
I ran a Nova head on my RG, and actually took it off after a while. I couldn't get consistent temp readings with the head, and there was a huge temp gradient between the crankcase and the top of the head (up to 50 degrees from what I saw)
Basically, my consistency improved when I went back to the stock head, and it was easier to get dialed in because everyone I race with was using the stock head, so I could mimic their needle adjustments and not have to adjust them much.
I might try the head again in the future, but for the moment I'm happy with the stock head.
I'm using an OS 2050 pipe with my RG and getting better fuel economy than any other RG racer I've come across. The power's been plenty good as well.
SkarTisu is offline
Old 07-26-2006, 12:00 AM
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
Another RG fan here.
I have the stock head...runs 230 or so and runs with pretty much anything at Revelation. I'm not an expert, but I had one drive it the other night and he was kicking the crap out of another good guy with a C6BB...LOL...with a $100 motor.
I don't know what it it compared to a JP-1 or T2050, but I have a 9886 pipe on mine and I don't seem to be lacking anything anywhere. Great deal and it holds a tune.
Turbo Joe is offline
Old 07-26-2006, 05:12 PM
Swede#1's Avatar
Well, it looks like ive been screwed over, i think the guy who was selling the Mayhem sold it to someone else And we had an agreement, oh well, i guess you just cant trust people theese days
Anyhow, thanks for your advise and help, atleast now i know what to get if and when i get another buggy
Swede#1 is offline
