Old 07-22-2006, 08:10 PM   #1
Default *old* losi jrx2/pro front and rear wheels
I have a few old jrx2/pro buggies and was wondering if any of the newer buggie or truck wheels will fit on these.
I expect them to be a bit taller, but that's fine. Any ideas/thoughts?
bibleboy is offline   Reply With Quote
Old 07-22-2006, 10:00 PM   #2
The Associated front B3/B4 rims and the Associated B3 rear rims will work - these will let you mount the newer 2.2" tires on the car. Make sure you get the B3 wheels as the B4 wheels have a different offset that will not clear the travel-links on the trailing-arm suspension on the JRX2. If your cars do not have the trailing-arm suspension then either of the Associated or Losi rear rims should work.
I have one as well that I keep for nostalgia reasons and was able to update the tires for the rare times that I want to take it to the track. XX, or XXX front rims will not work since they put all the wheel bearings in the hub - you need to have a front rim that allows for bearings to be installed in the rim (like the Associated stuff). Duratrax buggies also has rims that may work and are a little less expensive.
duckman996 is offline   Reply With Quote
Old 07-23-2006, 01:58 AM   #3
Thanks duckman996, I appreciate the info.
BTW, do you think it is possible to be competitive with one of these old buggies?
Old 07-23-2006, 06:08 AM   #4
Check eBay. I built a vintage JRX2 from parts on eBay. I am sure you could fine the original rims there.
AETC5 is offline   Reply With Quote
Old 07-23-2006, 07:02 AM   #5
ahsikes's Avatar
Trader Rating: 17 (100%+)
I will be posting quite a few vintage items including new in package rims and tires.
It will be later this afternoon. Thanks.
ahsikes is offline   Reply With Quote
Old 07-23-2006, 12:06 PM   #6
Competitive - yes.... win against the likes of top Pro's - I doubt the equipment matters - they can just outwheel 99% of us. Just to prove this point, a local off-road track just opened and I am going to running some really retro cars for the following:
1) I just love the way certain "oldies" look and sound.
2) I like to be different.
3) With today's electronics / motors, these older cars would only be faster. Couple that with some new tire compounds and IMHO the difference will be minimal.
Good luck with the JRX2 bibleboy - you should have lots of fun with it ... and if you really think the car is holding you back, then upgrade. IMO, RC racing is 70% wheel skills, 20% luck, and 10% equipment.
Old 07-23-2006, 08:08 PM   #7
Thanks to all for the info. Roger that on the equipment vs. skills. It seems like it would be easy to get caught up in *buying the latest gear* only to find out, the same wheelman is at the control.
I plan on putting these buggies to the oval. Any tips on setup would be appriciated.
BJ4, XXX4, B44 front and rear wheels Michal101 R/C Items: For Sale/Trade 38 07-10-2012 09:22 PM
Team Losi 8ight Front and Rear Chassis Braces and KingHeadz Rear Toe meon99 R/C Items: For Sale/Trade 14 07-23-2008 09:24 PM
vintage team losi jrxt rtr parts jrx2 wheels tires TZona R/C Items: For Sale/Trade 17 04-06-2007 05:37 PM
HELP! Front & Rear wheels opposing one another nikkor Singapore R/C Racers 9 11-16-2006 06:24 AM
japanese trend, rear body posts in front of rear wheels? floodo1 Electric On-Road 13 11-19-2005 07:20 AM
