Old 07-27-2006, 03:17 AM   #16
B4james's Avatar
I wont be doing these modifications until after the Australian TCS as the chassis brace will make the car illegal.
B4james is offline   Reply With Quote
Old 07-27-2006, 12:14 PM   #17
akuhon's Avatar
Yes, of course... this is not for TCS...
This car is meant for modified class..... I plan to run with 10T old Yokomo mod motor, with QC2.
Also, any tips on Bender's website will make it illegal for TCS (IMO)... especially the steering modification ...
I still waiting for the oil damper set, and still selecting the appropriate turnbuckles... Alums (Tobee Craft) or Titans (AE B4). What do you think ?
And for the diff joint replacement (see my 3rd question), it won't work.... the bearing placement is wider for this lt. weight diff joint (TA04 and RF415) than the original DF-03 diff joint.
Rgds,
akuhon is offline   Reply With Quote
Old 07-27-2006, 08:44 PM   #18
B4james's Avatar
I have read on a couple of the other forums that the front diff joints will fit the rear which eliminates the plastic rings.
Old 07-28-2006, 01:09 AM   #19
akuhon's Avatar
I'm a bit confused ....
The stock diff joint don;t have rings ....
And where are the forums you read on about this topic (diff joint replacement).
Thanks for the info, mate.
Old 07-28-2006, 02:53 AM   #20
Front diff outputs will fit the rear, by rings, he means the plastic diff ring carriers that the outputs sit on. If anyone is interested, I can get some super hard composite outdrives made from the same material used on spool/one-way front units??
Akhunon, make sure you get PLENTY of cooling in there for the ESC.
DA_cookie_monst is offline   Reply With Quote
Old 07-28-2006, 11:12 AM   #21
akuhon's Avatar
Oh ... you mean the black plastic on the rear diff ?
OK.... So I can change the rear diff outdrive with the front diff outdrive ?
There's still one diff joint I might try, the TA05 diff joint....
But I'm a bit lazy 'cause I have installed the chassis.
BTW, thanks for the info.
Rgds,
Old 08-10-2006, 05:12 PM   #22
JevUK's Avatar
Yes you can use front diff halves in the rear but not the other way around.
JevUK is offline   Reply With Quote
Old 08-19-2006, 11:21 AM   #23
badboy's Avatar
Trader Rating: 14 (100%+)
Default DF03 Tires
Hi. Would anyone know the difference between these two sets of DF03 tires? Will be running on carpet, what would be best between these two?
SPARE PARTS
51240 SP1240 HD Spike Tire K Front 62/25
51241 SP1241 HD Spike Tire K Rear 62/35
OPTION PARTS
53878 OP878 HD Spike Tire C Front 62/25
53879 OP879 HD Spike Tire C Rear 62/35
slow is fast . . .
badboy is offline   Reply With Quote
Old 08-28-2006, 03:11 AM   #24
akuhon's Avatar
SPARE PARTS
OPTION PARTS
Are you sure, you will use DI on carpet ?
Then, those are not the right ones...
Old 08-28-2006, 03:17 AM   #25
akuhon's Avatar
Default DF-03 with Tobee universal shaft
Does any experience the above title...
Well... I did..... I think it's a must to have them... no shaft pops up anymore... (I did some steering adjustment .... to the most..)
One suggestion if you will use this Tobee shafts is don;t forget to shim between the wheel hex hub and the outside bearing....
Front is 0.4 mm and Rear is 0.6 mm. Tamiya release the 5mm shim with thickness of 0.1, 0.2 and 0.3mm.
DF-03 DARK IMPACT mrcyclone Australia For Sale/Trade 2 05-12-2008 02:51 AM
Dark Impact tonyking73 Electric Off-Road 14 03-22-2008 08:26 AM
Dark Impact vs. RS4 MT Cain Electric Off-Road 5 11-20-2007 06:27 PM
WTB SYD Dark Impact Johnn Australia Wanted to Buy 0 12-13-2006 08:58 PM
dark impact streetracer745 Electric Off-Road 4 12-07-2006 01:45 PM
