ESC and top end speed >
Old 07-11-2006, 06:53 AM
Iceracer's Avatar
Default ESC and top end speed
How much difference does the esc make in the top speed of a car with a stock motor? Will I see a difference between the top speed and acelleration in my car if I upgrade my ESC from an old Novak Duster II to say a cyclone or GT model?
Iceracer is offline
Old 07-11-2006, 07:43 AM
The top speed will virtually be the same (the lower resistance of the better ESCs may give a fractionally higher top speed but nothing you would notice without a timer).
The advantage to a better ESC is in the middle range because they have more "steps" to make the throttle smoother and more controllable. Also the braking is better with a forward only ESC.
AreCee is offline
Old 07-11-2006, 08:26 AM
Iceracer's Avatar
That's good to know. I wasn't sure if there was a significant difference between the wide open throttle among the various speed controllers.
Iceracer is offline
Old 07-11-2006, 09:25 AM
cbrfreak's Avatar
The biggest difference in speed and punch in the stock class comes from batteries.
cbrfreak is offline
Trader Rating: 29 (97%+)
the lower resistance will also result in more punch.
party_wagon is offline
Old 07-11-2006, 09:26 AM
Iceracer's Avatar
Wonder if I lose much by charging my batt's the night before? Should I be repeaking them at the track?
Iceracer is offline
Old 07-11-2006, 09:49 AM
cbrfreak's Avatar
I charge my batts the night before the race at 5 amps because of time limitations. When I get to the track I re-peak at 6 amps and they usually cut-off after about 450 mah. I have good punch that way.
cbrfreak is offline
Old 07-11-2006, 12:16 PM
Iceracer's Avatar
Thanks, I'll try that. Was avoiding hauling more and more and more stuff to the track!
Iceracer is offline
