Old 07-10-2006, 08:07 PM   #1
Default New to elec. need help.
I just got a T4, and the only charger i have is a superbrain 959. I dont have a way to discharge, except for running the batt. in the truck.
Question is, what is a good charger and discharger/equal. I was looking at the duratrax ICE, and the Novak tray with the led and voltage cutoff (forgot the name) is this ok?
IB 3800's and a unlabled stock motor
Thanks, Derrick
derricklong38 is offline   Reply With Quote
Old 07-10-2006, 08:10 PM   #2
Trader Rating: 20 (100%+)
Send a message via AIM to tradhunt Send a message via Yahoo to tradhunt Send a message via Skype™ to tradhunt
Hey Derrick,
Welcome..... Yes the Ice and the Novak smart tray are great option's ....very afordable... but you need a powersuppy for them.....well the Ice you do.... I use both and really like them....
tradhunt is offline   Reply With Quote
Old 07-10-2006, 08:13 PM   #3
radioshack has a 25 amp PS for $41!!! so imma pick it up.
Old 07-10-2006, 08:15 PM   #4
sounds like a good setup to me.... I think you'll be happy
Old 07-10-2006, 08:16 PM   #5
Talking
and since I only have 1 battery, what is a good routine for it on race day, it doesnt seem to have too much umph to it. i have just run it down and chargerd it up, (letting it cool) not equal or nuttin, is this ok?
Old 07-10-2006, 08:19 PM   #6
run it down...... discharge it on youre Ice..... EQ on the tray.... let it cool....then charge it up....you'll notice a difference..... I did..... I use a zero30 discharger not the Ice...... but the Ice work's....
Old 07-10-2006, 08:21 PM   #7
thanks for all the help!!
are there any "special settings" for the ice that i would need to know about?
Old 07-10-2006, 08:30 PM   #8
Hey Derrick...you got a PM
Old 07-10-2006, 08:32 PM   #9
Trader Rating: 28 (100%+)
You should go to radioshack and buy one or two of there gp3300 stick packs. One battery is not enough for a raceday if you want to run it, discharge it, let it cool, then charge it again. The battery will probably take a half hour or more to charge, and if you let it cool first you'll probably not have time for your next run. Plus that's asking alot of your one battery to run a whole raceday with some practice. Radioshack sells the stick packs for like 25 or 26 bux I believe.
jbrow1 is offline   Reply With Quote
Old 07-10-2006, 08:55 PM   #10
Trader Rating: 114 (100%+)
Send a message via AIM to Valentin.H
i wouldnt buy those gp3300s from radioshack. they arent matched or anything..they are just a bunch of "non-wanted" cells that the factory just slapped together. i suggest you go to horizon, they have a gp3900 by orion in a stick pack forum, and those should be good. or save up and get some decent new or used matched packs. btw, change ur plugs to deans.
-valentin
www.csjunkies.com
Valentin.H is offline   Reply With Quote
Old 07-10-2006, 09:11 PM   #11
I was just lookin to save a new guy in racing a few bucks until he learns to keep it between the tubes.
Personally I'd still recommend the radioshack batts, keep the charger you have, and build your own discharger out of 1157 lightbulbs from the auto parts store.
Then take what you would've spent and buy some tires/wheels, spare arms, and for the T4 couple servo saver kits. They are only 5 or 6 bux.
Any as said above, go with Dean's plugs they are the best.
Old 07-10-2006, 10:52 PM   #12
Trader Rating: 26 (96%+)
These aren't nicd cells. First off, the charger you currently have should be all you need for now. As far as a discharger is concerned. The integy zero/thirty is probly the way to go. Typicaly people will use a novak smart trey and the trinity dyna pulse togather. However, the zero/thirty will get the job done on it's own. You will need to do a little research on the best process for the discharging and charging cycles though. I would try to bring at least 3 packs to a 4 heat race day. For off road racing all you realy need are matched packs of nimh cells. Yes, there are the ib 4200s and ect, but all you realy need are some gp 3300s for off road.
party_wagon is offline   Reply With Quote
Old 07-10-2006, 11:31 PM   #13
RCBLUE's Avatar
I agree about the zero 30, I have had one since they were released and my batts are superb. I would recommend going to your local track and putting out some feelers for some good used packs. Don't just buy the first ones you come across without first getting some opinions from several other racers. You never know who wants to sell their junk to some unsuspecting victim.
Don't sweat the petty things...........Pet the sweaty things!!
Serpent America
Lunsford Racing
RCBLUE is offline   Reply With Quote
Old 07-11-2006, 06:28 AM   #14
Typicaly the person who runs the races will normaly have a good feal on who is offering you garbage and who is offering you decent packs.
Old 07-11-2006, 11:01 AM   #15
Having a Super Brain 959, they SUCK for racing batts, they can only charge at 4.5 amps. I typically use my superbrain for rx packs and maybe my mini-t. There are 2 Integy chargers that discharge at up to 30 amps, adn can charge at a higher amperage then you would need. The ICE is also great, however this does need a power supply whereas the Integys do not require a ps. I currently use lightbulbs and then the zero-30 right before charging to equalize the cells. Looking to maybe get a reactor 30 for discharging. I can also discharge with my Integy Charger at any amp from .01 to 30 amps.
HTH
Rod
gatermaxx is offline   Reply With Quote
4wd elec 20 SMOKE R/C Items: Wanted to Buy 3 07-04-2007 12:45 PM
WTB 4WD 1/10 ELEC zrchobbies R/C Items: Wanted to Buy 12 07-08-2006 06:25 PM
RS4 MT Elec NVisible R/C Items: Wanted to Buy 5 07-06-2004 04:00 PM
Wtt 4 elec 4 tec Spoons Pede R/C Items: For Sale/Trade 0 05-21-2003 12:44 PM
Elec Tc3???? |BlackLabel| Electric On-Road 3 02-12-2003 04:53 PM
