Make a 1/8 buggy wheelie?
Is it possible to make a 1/8 buggy wheelie? I was thinking of maybe putting 15K or 30K in the center and 5K or 7K in the front/Rear... That along with some 60-70 weight shock oil in the rear. Or what type of setup would possibly make a 1/8 buggy wheelie if it would hit a small bump/rut for a little help?
Just going to have some fun with an extra buggy that I don't race with..
maybe you could lock the center diff and take out the front drive shaft and run heavy diff fluid in the rear diff. it will probably wheelie best on pavement
put silly putty in the center diff and put realy soft springs in the rear.
Hey Valantine,
Are you the stocky Chinese kid about 5'3" at 200 lbs ? With a buzz cut ? Where do you drive at ? I think I know the dude with the Hyper7.
Later
Later
I can make my buggy wheelie. Wheelie right past you that is G.LOL Gas er up Grant.
The silly putty in the center diff will lock it up w/out causing any damage to it. This will allow the rear tires to have power when the front is off the ground.
The soft springs in the rear will help the weight of the car to transfer to the back of the car. This will give you superior rear traction and leave the weight of the car on the rear end so that it takes less torque to lift the front of the car. This should make it wheely all day on demand.
if all you want to do is make a buggy wheelie. just hold it at 45deg angle and then it it rip. you should be able to go hundred feet+
lock center diff.....might wana use less teeth on the clutch bell aswell.....lighter clutch shoes
Ya I making some silly puddy this weekend to give it a try.
I want the buggy to wheelie on command without my intervention of touching the buggy... This buggy is just a play/fun buggy.... going to use it on a skateboard ramp, see if it will survive. It's a PRP Swift buggy I bought SUPER cheap.
your going to make silly putty? just go up to your local dollar tree and pick some up.
