xxx-4 g+ problem please help!!!! > xxx-4 g+ problem please help!!!!
Old 07-06-2006, 09:26 PM
Suspended
mrctattoo's Avatar
Trader Rating: 8 (83%+)
Default xxx-4 g+ problem please help!!!!
hey guys i got this xxx4 use from a buddy of mine, is a freacking fast buggy but when i aply the brakes i hear a clicking noise, and when in heavy loads too, i try loosing up the slipping clutch but with no luck, can any one help?
thanks in advance
mrctattoo is offline
Old 07-06-2006, 09:28 PM
Its just the belt, its fine dont worry.
Chris Jarosz is offline
Old 07-06-2006, 09:29 PM
PDI
Sounds like your belt is a little loose. Its okay to get a few clicks on full brake but if it is excessive than just tighten it up a little.
PDI is offline
Old 07-06-2006, 09:52 PM
Suspended
mrctattoo's Avatar
Default hey
guys thanks
i gues i shout tight the belt up a bit more thanks
Old 07-07-2006, 04:39 AM
Scottmisfits's Avatar
When you take off the gear cover on the top, there should be around 1/8" of play in the belt when you push down on it. The belt will still skip. It's part of the design, so don't worry about it.
Scottmisfits is offline
Old 07-07-2006, 05:58 AM
I don't think you should hear it under accel. though, only under braking.
Jay
pyro18t is offline
Old 07-07-2006, 12:45 PM
Buckyaga's Avatar
shaft drive will fix that problem right up
/me runs
Buckyaga is offline
Old 07-08-2006, 12:54 AM
Suspended
mrctattoo's Avatar
Thumbs up
thanks guys for the info, i tight it up and there, no more cliking noise
i use the top hole on the tension bar and the belt is tight but i can move it just a bit thanks
Old 07-08-2006, 06:59 PM
/me runs
Yeah, but who wants a slow car?
pyro18t is offline
