Old 07-04-2006, 05:40 PM   #16
Scottmisfits's Avatar
Yes they are digital. I have been using digital servo's in everything I run.
Scottmisfits is offline   Reply With Quote
Old 07-04-2006, 06:01 PM   #17
Super Moderator
Funkymojo's Avatar
Location: Singapore ̡͌ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡V
Trader Rating: 75 (100%+)
Thanks buddy..does ACE have a website? Thanks
WANKING - Extreme agitation and arousal - usually south of Nanking and short of Farking.
I'm neither a Mod nor a Rocker. I'm a Mocker.
Viper R/C Solutions | Atomic Carbon CR2 LWB | Darth Tray | Losi 8IGHT 2.0-E | Tamiya TRF801X-E
Funkymojo is offline   Reply With Quote
Old 07-04-2006, 06:16 PM   #18
Super Moderator
Funkymojo's Avatar
I've got a Ko Propo PDS-2143 Hi Speed servo that has got 111oz/8kg of torque...can i use it as a throttle servo for my 1/8 GP buggy?
Old 07-04-2006, 07:22 PM   #19
How fast is it?
http://www.acehobby.com/ace/index.htm
That's Ace's website. The servo's are on the right hand side of the page. And looking at the spec's again, tht's the torque and speed at 4.8v, not 6.0volts.
Old 07-04-2006, 08:36 PM   #20
KK-racing's Avatar
Most commonly used over at our side of the globe is the Sanwa(Airtonics) ERG-VB/ZB, for it's high torque & reliability.
It would be advisable to take note & avoid the below servo at all cost. Was rather apprehensive about the too good to believe price & specs., so to find out how good you have to try it first right ?. We bought a few pieces & 1 of them failed within a 7 mins heat runtime. Turn it on & you hear the so-called 'digital chattering'. Steer left or right 'full lock' & the servo horn moves to the end & instead of stopping at the end point, it moves back & forth 2 ~ 3 mm a few times before it stops. Same thing happened when used on the throttle(as a bonus you get ABS braking effect ). We have dumped the rest aside.
TOWER PRO MG-945
(METAL GEAR SERVO)
(ULTRA TORQUE)
13 kg Torque
<DIGITAL>
Specification :
Weight : 55.2g
Operating speed:0.24sec/60degree(6.0V)
Stall torque:13.0kg/cm (6.0V)
Temperature Range:-20 degree to 60 Deg
Dead band width:4usec
Operating Voltage:4.8V~7.2V
Structure Feature: 3 pole ferrite, dual ball bearing, 3 metal gears and 1 Resin metal gear, connector wire length: 32cm
PRICE USD20
Just remember :- 'Good things no cheap, cheap things no good !'.
Do 'IT', with a DUREX (safely) !!!
KK-racing is offline   Reply With Quote
Old 07-04-2006, 09:15 PM   #21
Rysuleod's Avatar
Originally Posted by LSUsportsfreak
Futaba S9350
Seconded for steering. I use an average JR590M for throttle .. because it works! You shouldn't need high torque on a slide carb!
Rysuleod is offline   Reply With Quote
Old 07-04-2006, 10:14 PM   #22
I would suggest the Airtronics 94359.
WWW.RCRARACING.COM
wake is offline   Reply With Quote
Old 07-04-2006, 10:27 PM   #23
Nitro21's Avatar
9351 Steering 192oz [email protected]
9350 Throttle 138oz [email protected]
I run these in a TTR S3 Excellent choice
But you couldnt go wrong w/Airtronics 94358/59 Steering and 94357 Throttle either thats what I run in Unlimited...
Nitro21 is offline   Reply With Quote
Old 07-04-2006, 10:31 PM   #24
CaseyP's Avatar
But you do need torque for brakes. Especialy for those long mains where the servo gets quite a beating.
<>< The Truth Will Set You Free!
TLR / Team Orion / Spektrum / AKA / TEKIN / Horizon Hobby / upgrade rc / AVID / SCH / SPY / HAL'S HOBBY WAREHOUSE
CaseyP is offline   Reply With Quote
Old 07-04-2006, 10:36 PM   #25
And you want speed for the response. That's why I liked the Hitec's and I am running the Ace servo's now. Even better spec's on 4.8 volts that the Airtronics at 6.0v. and cheaper too. To me that's a no brainer.
Old 07-04-2006, 11:59 PM   #26
Super Moderator
Funkymojo's Avatar
My Ko Propo PDS-2143 Hi Speed servo is 0.08 S @ 60 at 6v...good enough to use as a throttle servo?
Old 07-05-2006, 01:59 AM   #27
BigRed's Avatar
Trader Rating: 20 (100%+)
ko pds-2433 for steering. 200oz of torque at .13 6v. You can also just buy the plastic gear instead of buying a hole new gear set. $5 for a package of 4 i believe. Major bonus! I just bought the futaba futaba 9451 for the throttle servo, very nice. I've kind of steered away from Airtronics latley, i always seem to have centering issues with them.
BigRed is offline   Reply With Quote
Old 07-05-2006, 02:47 AM   #28
Super Moderator
Funkymojo's Avatar
Thanks for the advice but my ko pds-2143 with the speed of 0.08 S @ 60 at 6v and 111oz/8kg of torque is good enough for throttle usage right?
Old 07-05-2006, 05:33 AM   #29
That's a good enough servo for throttle or steering. A little more torque would be nice for the steering but that is adequate.
Old 07-05-2006, 08:54 AM   #30
Rysuleod's Avatar
You are correct. I didn't think of the brakes because I don't use them very much !
looking to buy new steering servos steven19 Electric Off-Road 7 02-18-2007 01:08 AM
wtb steering servos steven19 R/C Items: Wanted to Buy 2 02-10-2007 09:47 PM
WTB steering servos weidjd R/C Items: Wanted to Buy 2 11-17-2006 07:30 AM
1/8th steering servos Mr-s413bt Electric Off-Road 26 05-25-2006 07:45 AM
Let's talk 1/8 Buggy steering servos.... MikeyG Electric Off-Road 27 05-16-2005 05:36 PM
