Old 06-29-2006, 09:30 PM   #1
JatoPimp's Avatar
Angry Glow Plug Trouble.....
hey guys im kind of new to the nitro thing but i keep having to replace glow plugs alot like 2 in 2 days! thats not normal right? any help would be great thanx alot!
JatoPimp is offline   Reply With Quote
Old 06-29-2006, 09:36 PM   #2
Trader Rating: 22 (100%+)
sounds like either you have a bearing going (metal shavings) out or dirt in the engine kncocking out the glow plug
sand geek is offline   Reply With Quote
Old 06-29-2006, 09:54 PM   #3
JatoPimp's Avatar
i dont see shavings if its dirt than how do i fix it? i think im on the ritch side a little to but dont you have to be like really ritch to be messing up glow plugs?
Old 06-29-2006, 09:56 PM   #4
Bit_Rusty's Avatar
Hey.
I read somewhere else that you've just gotten this beast? How many tanks has it been through?
You'll tend to foul plugs quite often until everything's nicely loosened up and you start leaning the HSN. i.e. as you're breaking it in.
Also... what plug are you using, what kind of engine and what % nitro content?
Ps. That avatar rocks.
Bit_Rusty is offline   Reply With Quote
Old 06-29-2006, 10:12 PM   #5
JatoPimp's Avatar
i have a TRX2.5 im using a hot standard long glow plug by Traxxas and i have had about 3/4 gallon of 20% traxxas top fuel.
Old 06-29-2006, 10:39 PM   #6
Trader Rating: 114 (100%+)
Send a message via AIM to Valentin.H
try mccoy plugs. best in the business when i use to run nitro. thats all i ran, mccoy plugs and odonnel fuel.
-valentin
www.csjunkies.com
Valentin.H is offline   Reply With Quote
Old 06-30-2006, 03:16 AM   #7
ProudSavageOwnr's Avatar
Send a message via MSN to ProudSavageOwnr Send a message via Yahoo to ProudSavageOwnr
you may be running too rich or too lean.......too rich and its gona dismantle the element and too rich itll burn it out and make it go grey down the bottom...you read the plug by looking at it..if its nice n shiny down the bottom its good
FG leopard comp w/Trevor Simpson 28.5 bzm crank
HIP Baja 5sct
AE tc5 3.5t speed monster,Futaba 4pks
Raptor G4 ,Raptor e550,Gaui x5,Mini titan v2,Precision aerobatics bandit 4s monster,Carbon z scimitar Jr 11x
ProudSavageOwnr is offline   Reply With Quote
Old 06-30-2006, 10:09 AM   #8
JatoPimp's Avatar
what do you mean shiny at the bottom? bottom of the element?
Old 06-30-2006, 06:28 PM   #9
yeah at the bottom of the element....and the bottom of the plug should be a caramel colour aswell as wen u look inside the glowplug hole
HIP Baja 5sct
Old 06-30-2006, 11:45 PM   #10
SkarTisu's Avatar
Send a message via AIM to SkarTisu Send a message via Yahoo to SkarTisu
....and if the element's moved around inside the plug, then you're probably detonating which is caused by running too lean, or too hot of a plug. You can tell for sure if you're detonating by pulling the head and looking at the top of the piston. If it looks like it's been sandblasted, then you're detonating.
SkarTisu is offline   Reply With Quote
Old 06-30-2006, 11:55 PM   #11
to check if your glow plug is dead, jsut hold it, and touch it a little with your igniter, it should light up super red and bright.
-valentin
www.csjunkies.com
Old 07-01-2006, 02:13 AM   #12
and if ur detonatiing u should install 1 or more head shims....
HIP Baja 5sct
What glow plug do i need? rockfordccinc Nitro Off-Road 2 01-29-2008 03:16 PM
Engine won't Rev Up and Glow Plug Trouble tarheel23 Nitro On-Road 5 07-25-2006 08:26 PM
glow plug help timmy187 Monster Trucks 3 04-19-2006 08:56 PM
glow plug ? jonnyc Rookie Zone 6 03-03-2006 11:13 PM
GLow plug. zoombie Nitro On-Road 5 07-06-2003 06:31 PM
