Old 06-23-2006, 01:05 AM   #16
Thai3g_Eclipse's Avatar
Originally Posted by SavageGoZoom
I got a mini-t and for cheap I would say get a Baja... I am on my 2nd baja and love it...
well thats actually changing... on tuesday I will have a mamba 8000, mamba speed controller, mamba conputer conector cable, 2 lipo charges, and a lipo that is freid(using the conectors off it)
Word of advice, don't use a 3 cell LiPo with that Mamba 8000, I've already gone through 2 ball differentials and a gear differential lasted a good whole 2 minutes. If you feel like doing it anyways, make sure that slipper clutch is not tightened; keep it lose and progressively tighten it until you get it to "grab" just right.
HPI Savage Flux HP | Tamiya TB-03
Thai3g_Eclipse is offline   Reply With Quote
Old 06-23-2006, 02:18 AM   #17
Michael P's Avatar
i had a mini t and now i have a rc18t(truggy) its so much better 4 wheel drive insted of 2 more hopup parts all around beeter car.
mike
Michael P is offline   Reply With Quote
Old 06-23-2006, 08:12 AM   #18
I'm running a Mini-T with a 8000 BL setup, and only recently installed the DD-Slipper. I haven't actually run it yet, but to be honest, I'm looking toward the day when the BL and Lipos come out and go into a Xray M18T.
Those things are supposed to rock, although I'll try to find myself a cheaper 2nd hand one if i can.
A_Stevens is offline   Reply With Quote
Old 06-23-2006, 09:58 AM   #19
SavageGoZoom's Avatar
Send a message via AIM to SavageGoZoom Send a message via MSN to SavageGoZoom
Link me to the best lipo i can get for it?
SavageGoZoom is offline   Reply With Quote
Old 06-23-2006, 12:40 PM   #20
Trader Rating: 26 (96%+)
maxamps.com
Get a 2100 mah 7.4 volt pack. It will push the car at around 30 miles per hour with the 6800 system. For a charger I would get the duratrax ice w/ a decent power suply. You should get around 25 minutes of run time easily as well. As far as kits are concerned, the new trinity blade pro ARR looks like the best bargain. The parts quality is actualy good and the roller is $100 w/ a servo. That would put you at $100 for a great roller, $80 radio, $100 brushless, batteries and charger.
party_wagon is offline   Reply With Quote
Old 06-24-2006, 07:58 PM   #21
Originally Posted by party_wagon
maxamps.com
Only 30 I want fast What is there that will make my 8000mamba hit 50-60?
Old 06-24-2006, 08:21 PM   #22
Trader Rating: 114 (100%+)
Send a message via AIM to Valentin.H
mamba 8000 is basically uncontrollable with even nimh. 6800 is your best bet, more torque too
-valentin
www.csjunkies.com
Valentin.H is offline   Reply With Quote
Old 06-24-2006, 08:32 PM   #23
I already got the 8000K because I got it for dirt cheap
But so how fast will it go with that 2100 7.2 lipo?
Old 06-24-2006, 08:39 PM   #24
OK these are them and both say"PERFECT FIT FOR YOUR RC18T BRUSHLESS" but will they fit a mini-t?
7.4
Rated at 10C or 20 amps
Comes with Hyperion Taps
34mm X 95mm X 16mm
95g
11.1
34mm X 95mm X 24mm
140g
Old 06-24-2006, 11:40 PM   #25
It probably won't fit becuase the RC18T has a longer, thinner battery compartment than the Mini-T.
RC18Ts have 5-6 cell packs built side by side (although I've seen stick packs too), whilst the Mini-T runs 4 side-by-side with 1-2 along the top for the 5-6 cell packs.
Old 06-25-2006, 12:38 AM   #26
I cant find mini-t lipos anywere
Old 06-25-2006, 10:29 AM   #27
7.4v 2 cell: http://www.horizonhobby.com/Products...rodID=EFLB1010
11.1v 3 cell: http://www.horizonhobby.com/Products...rodID=EFLB1015
I have the 3 cell and the battery height is slightly higher than a NiMH pack, so the fitment is nice and snug. Fits very well and doesn't move around.
Old 06-25-2006, 12:14 PM   #28
How come they are so small Theres 2100 for rc18s there has to be a bigger 11.1 volt for the mini-t...
Old 06-25-2006, 12:38 PM   #29
I'll let you know Tuesday. I forgot I have a 2100mAH 3 cell LiPo sitting around and I can test fit it. It is considerably larger than the 1200MaH though, so it'll be a pretty tight fit.
Old 06-25-2006, 01:04 PM   #30
I don't think you understand how fast you are saying you want your truck to go. The truck will literaly crumble if it hits a curb going 50 m.p.h. Go with the mamba 6800 version and a 7.4 volt lipo. If you go with the 8k mamba and a 11.2 volt lipo I would advise that you invest in perhaps the integy aluminum vonversion kit for the mini-t.
Associated, HPI Micro, Kyosho Mini Z, Xray M18, Losi Mini T unsponsored Australia Wanted to Buy 9 06-23-2017 07:36 AM
Wanted-Associated, HPI Micro, Kyosho Mini Z, Xray M18, Losi Mini unsponsored R/C Items: For Sale/Trade 0 05-19-2008 04:54 PM
Review of French prototype Mini XXX built on a Losi Mini T Pro moumerico Micro and Mini Scales 4 03-21-2008 02:19 PM
Losi Mini T - RC18T - Kyosho Mini Inferno Hunter73 R/C Items: For Sale/Trade 23 03-30-2007 05:16 PM
Brand New - 4 TEAM LOSI Mini-ATX Tires w/Foam & Wheels for MINI-LST JG24FAN R/C Items: For Sale/Trade 2 12-09-2006 03:57 PM
