Old 06-17-2006, 05:58 PM   #1
Send a message via MSN to rhymster
Default endpoints and how to set them
i have a xxxnt. my throttle servo doesnt move in or out very much in either direction enough to pull the carb almost all the way open but not quite and there is no brake i was wondering if this could be the endpoint adjustments fault and i also have no idea how to set it. my throttle servo is a jr z550
rhymster is offline   Reply With Quote
Old 06-17-2006, 06:10 PM   #2
Scottmisfits's Avatar
End points don't have anything to do with how you use the servo's.It's a limit for the throw of the servo's, set through the radio.
What radio are you using? It's pretty easy to set them, and once they're set correctly they will help save your servo's as well.
Scottmisfits is offline   Reply With Quote
Old 06-17-2006, 06:14 PM   #3
i am using a futaba t3pdf i dont know when the raio is off i can move the servo to out and in prolly like 2 times farther then when the radio is on and the brake really isnt applying that much pressure to it do u think my servo is bad?
Old 06-17-2006, 06:23 PM   #4
No, you're servo will do that. The EPA just limit's it when there is power. It's an elctric brake for the servo for lack of better terms.
If I'm not mistaken,you have a display screen for making the adjustments. Look for EPA or travel or something along those lines.
Old 06-18-2006, 06:25 AM   #5
GregH's Avatar
Send a message via AIM to GregH
damn that chick is hot in your avitar....
GregH is offline   Reply With Quote
Old 06-18-2006, 10:25 AM   #6
ko helios steering endpoints cheesecake Radio and Electronics 7 11-15-2007 06:23 AM
