Old 06-07-2006, 06:17 PM   #1
Default Team Losi XXX-CR
So whats needed to convert the BK2??
http://www.teamlosi.com/Products/Pro...rodID=LOSA0032
stumper is offline   Reply With Quote
Old 06-07-2006, 06:37 PM   #2
Trader Rating: 114 (100%+)
Send a message via AIM to Valentin.H
alot...your better off than just buying a xxx-cr..
-valentin
www.csjunkies.com
Valentin.H is offline   Reply With Quote
Old 06-07-2006, 07:13 PM   #3
Default cr
yeah after reading more about it i see that....
Old 06-08-2006, 09:12 AM   #4
Casper's Avatar
Trader Rating: 34 (100%+)
You can bolt all the CR stuff onto the Bk2 but they made the car out of new material that is supposed to help the car handle better and be more durable all at the same time. It will be cheaper to sell you Bk2 on ebay and get a new kit.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 4.0, TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 06-09-2006, 11:47 PM   #5
beaverltd's Avatar
Wondering if the Lightweight Outdrives for Gen II Transmission from BK2 will fit the CR. Or will the new XXX4 plastic outdrives work??
Where are you guys getting your CRs from??
Heard Another 2 weeks from Horizon!!
beaverltd is offline   Reply With Quote
Old 06-09-2006, 11:53 PM   #6
Casper's Avatar
I have not seen one for sale yet. I have heard as early as Monday the 12th but nothing offical. The Gen II outdrives will not work. They went back to the Gen 1 tranny which will use the XX4 oudrives. They did revise the outdrives for an inproved diff assy so I am not certain those will work with all the new diff parts but you could build a Gen 1 diff and use it in the car. The new CR diff is supposed to last forever from what the team guys are telling people.
Old 06-10-2006, 07:18 AM   #7
Your better off using the outdrives that come with the car. The diff is designed so instead of the rings slipping(or rubbing) on the balls, the rings slip on the outdrives. That way the rings and balls last alot longer and the diff stays super smooth.
Kyosho / Team Orion / AKA / JTP / Sharkbait Designworks / RC Tracks of Las Vegas
Chris Jarosz is offline   Reply With Quote
Old 06-10-2006, 12:34 PM   #8
CaseyP's Avatar
You can use the plastic outdrives from the xxx4. But you will have to use some of the xxx4 hardware. ie diff screw, belvelle washers and diff rings.
<>< The Truth Will Set You Free!
TLR / Team Orion / Spektrum / AKA / TEKIN / Horizon Hobby / upgrade rc / AVID / SCH / SPY / HAL'S HOBBY WAREHOUSE
CaseyP is offline   Reply With Quote
Old 06-10-2006, 06:21 PM   #9
Aaron Waldron's Avatar
There's more to the steel vs. plastic outdrive debate than just the weight involved. I really don't think you will see any lap time difference, even in stock or 19T, going to plastic outdrives in order to save rotating weight.
However, the friction each surface provides on the dogbone pins, as well as the flywheel effect (especially of the heavier steel outdrives) can make a difference as far as how the car drives.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 06-10-2006, 10:10 PM   #10
beaverltd's Avatar
Plastic outdrives dont wear and eventually bind the suspension.
The two materials (outdrive+dogbone pin)work well together and dont req lubrication..Weight saving is added bonus!..
Old 06-11-2006, 11:49 AM   #11
killer89's Avatar
Trader Rating: 41 (100%+)
Send a message via AIM to killer89
Can't wait till monday....
If I had the money right now, I'd be at my LHS when they open Monday morning...
killer89 is offline   Reply With Quote
Old 06-11-2006, 12:44 PM   #12
D Hunt 3's Avatar
Send a message via MSN to D Hunt 3
FYI- There is already a thread started for this. It's just "Losi XXX-CR".
D Hunt 3 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
Team Losi 4 Piece Nut Driver Set and Team Losi 4 Piece hex set (Metric) (like new) CRFXXXT R/C Items: For Sale/Trade 12 04-09-2008 10:49 PM
I've just read on LosiBk2.com that Team Losi are not sending a team to the worlds. Mabuchi540 Electric Off-Road 170 09-18-2007 05:32 AM
TEAM LOSI XXXT ROLLING CHASSIS INCLUDES TEAM KINWALD MOTOR AND 5 GP 3300 CELLS pcr2nv R/C Items: For Sale/Trade 1 04-23-2006 08:58 PM
** Team Associated announces plans for acquisition of Team Losi: A & L Racing ** G-spec Electric On-Road 5 04-01-2004 03:02 PM
