Old 06-04-2006, 09:17 AM   #1
Send a message via MSN to rhymster
Default problems with trinity draked .12
i got everything set up on my truck yesterday and went to start breaking it in and checked the needle settings first well th ehigh speed was fin but when i went to check the low speed it wouldnt even turn in either direction of what the factory needle settings were which is 3 1/4 i thought that was meesed up so i go to try and start my truck and there is way to much gas coming out the exhaust it wont even fire and it blows a little gas and air out the glow plug i took it out check the threads and put it back in a little over snug just like my other engines still does it the only way i can get the engine to fire is if i lean the needles out a crapload but i still have to keep my glow ignitor to keep it going should i send the motor to trinity?
rhymster is offline   Reply With Quote
Old 06-04-2006, 09:25 AM   #2
Trader Rating: 14 (100%+)
calm down there, and try using some commas and periods next time. It is not uncommon for the low speed needle to move really hard, I have had that problem on all of my 12 sized engines.
Go back and re-read the engine instructions, find out where the needles need to be for break in and re adjust them accordingly. The engine does need to run rich, you want a good bit of smoke coming from the exhaust. Have you heard of the heat cycle break in method? That is the best way to break in a motor. here is the link
Follow this and you will be ok, just make sure to keep the engine temp between 200 and 215. Don't let the engine run out of gas, when you see it running out, bump the flywheel with your finger.
Hope this helps
o.s. power is offline   Reply With Quote
Old 06-04-2006, 09:38 AM   #3
i tried that. but im not sure that the needle is spose to look all scraped up im know how to work on stuff but something just doesnt seem rightwhen i bake it into where it should be i can fell it being forced in the valve and the arm for the servo wants to get stuck
Old 06-04-2006, 09:42 AM   #4
i notcied that there is fuel even coming from the rubber seal around the low speed needle thing. and why would the glow plug be leaking
Old 06-04-2006, 10:08 AM   #5
subarubie's Avatar
rhymster:
On your problem with the needles beeing hard to turn, try taking them all the way out & lube the o-rings on the needles. They should be easy to turn after that.
On the problem with the glow plug leaking, do you have the seal (copper ring) on the glow plug.
subarubie is offline   Reply With Quote
Old 06-04-2006, 12:45 PM   #6
yes the cooper shim is there. and the needle valve do u mean like lube it with green slime. also it seems the needle wont turn out no more i know a o-ring wouldnt be holding it back but when i try and adjust it forward it almost jams into the seat it slides into cant u damage those pretty easy
TRINITY DRAKED PLATINUM 21 madmedic860 R/C Items: For Sale/Trade 14 06-17-2008 11:41 AM
TRINITY PLATINUM 28 DRAKED madmedic860 R/C Items: For Sale/Trade 4 05-17-2008 07:52 AM
trinity draked .28 anyone own this besides me? rhymster Nitro Off-Road 1 08-26-2007 03:31 PM
TRINITY .21 DRAKED pink_sleeve Nitro Off-Road 20 06-17-2007 02:16 AM
trinity draked .12 rhymster Electric Off-Road 31 06-02-2006 05:15 PM
