Old 06-03-2006, 01:19 PM   #1
Default How much diff oil in the Diff?
Hey guys I bought a Jammin X1 CRFT kit and I was wondering the manual told me to fill the diff boxes to 100% and I filled it with enough oil so that the gears were fully submerged in it, is that over filling it?
EDIT found my answer!
EnderWiggin is offline   Reply With Quote
Old 06-03-2006, 10:16 PM   #2
What's the answer? I've been wondering the same thing myself..
rwlkr is offline   Reply With Quote
Old 06-04-2006, 09:28 AM   #3
Trader Rating: 14 (100%+)
just enough to cover the shafts the spider gears are on.
o.s. power is offline   Reply With Quote
Old 06-04-2006, 10:54 AM   #4
Trader Rating: 15 (100%+)
Fill the diffs to 80% to allow for heat expansion!
7.5man is offline   Reply With Quote
Old 06-04-2006, 12:45 PM   #5
crap, well I filled mine right to the top of the gears and then screwed in the screws etc and lets it ooz out. The kit calls for loctite which type should I get?
Old 06-04-2006, 12:53 PM   #6
Oh and another question I put together the front gear case and it seems like the small bevel gear in it hits a rough spot around the diff. case gear should I worry at all about it? or is it just the gear around the diff case has to wear in?
Old 06-04-2006, 01:58 PM   #7
Guys:
The best way to build diffs are very simple if you do the right things.
1. Take diff cases either new or when rebuilding the first time on the flat side and rub them in a figure 8 motion on a flat surface on #400 emery cloth and then clean them . This will make the cases perfectly flatt.
2. Build the diff as instructed and fill them to 80%.
3. Place some silicone gasket sealent on the filled diff case. Then place the gasket on the diff case, line up the holes properly and give it about 10 minutes to set. Then place the large bevel gear (front or rear diffs) or spur gear (center diff) and tighten it down on the opposite rotating method. Just make the screws good and tight. There is no need to over tighten as you'll just strip the diff cases. Then take some of the silicone gasket sealent and place some over the head of the screws to cover them and some also on the small set screw. This silicone sealent is easily removed upon your next rebuild.
4.Then you shim your diff properly in the bulkheads as instructed. Then place some grease (I use AE black grease) on the bottom of the bulkheads before attaching them to the chassis. This will stop dirt from entering the diff area t and keep the bevel and pinion gears in much better condition and the internal clean.
5. Some diffs need to be reshimmed after some run in. Again go back to steps 2,3,4 and you should be set to go.
Your diffs should not leak if built properly and you should be able to get at least 2-3 gallons of fuel through them before the diff oils need cleaning and a rebuild is necessary.
enjoy.....
Old 06-10-2006, 03:21 PM   #8
I guess I'm just a jackass....
When you guys say "fill the diff" are you talking about one half of the housing? In other words, the housing splits in half (upper and lower cup). Do you just fill the lower cup 80%? As I said... I must be a jackass, cause I dont understand this... I guess I am confused because I can't figure out how you get oil in the housing with both 'cups' screwed together...
Old 06-10-2006, 04:21 PM   #9
holy crap... not only am I a jackass, but I must be smokin' crack... I just realized that the two 'cups' are just the damn housing... the actual differential is the case inside with the gear attached to it... man..
So, to put the icing on the cake, I cleaned out all of the grease that was inside the two housing halfs because I thought this is where you put the diff oil. Can I just put a little automotive grade axle/bearing grease back in?
Old 06-10-2006, 05:43 PM   #10
don't pack the housings with grease - that is the dumbest thing to do. It is ok to use a little grease on the gears - axle grease will work, just don't over do it.
Old 06-10-2006, 06:32 PM   #11
Another point to look at is the oil does not expand when it gets hot.One of the Jammin Team members at the Winter Nats in Red Deer told us to fill the diffs 100% full. It is like filling the shocks, you dont want any air and the operation will be more consistant. I have filled mine this way and they dont leak and work flawlessly. As 7.5man said , the cup must be sanded on a flat surface to ensure a good seal between the cup, gasket and gear. Have fun
B-TOWN is offline   Reply With Quote
losi xxxt ball diff change to a 1/10 desert truck diff newbie2 Electric Off-Road 49 12-13-2010 08:49 PM
NTC3 Complete ATD Diff, diff nut, pivot ball socket caps Judge Joe Brown R/C Items: For Sale/Trade 2 05-09-2008 10:18 PM
[B]Fioroni Center Diff And Front Diff And Ofna Torsion Diff For Hyper 7[/B] Imdadundada7 R/C Items: For Sale/Trade 22 08-07-2006 11:11 PM
front lock diff vs gear diff rhed Nitro On-Road 4 11-29-2005 02:20 PM
XRAY T1FK04, XRC 4.0mm Chassis, One-Way, Diff, Hudy Spring Steel Diff, and MORE! BobbyDoyle R/C Items: For Sale/Trade 10 08-18-2005 04:38 PM
