Old 06-03-2006, 10:36 AM   #1
Default Starter Box Set up
Hi, i just bought a team associated factory team starter box for my 1/8 OFNA buggy. The problem is, i have NO idea how to set it up-can anyone help me? i dont understand which way the flywheel should go, and how the buggy should sit on the box. Pics would be great. Thanks guys!
hawk44 is offline   Reply With Quote
Old 06-03-2006, 08:40 PM   #2
On most designed bump boxes the rear of the vehicle is the end that you will push down to activate the wheel. From there you will want the wheel to be directly over the flywheel on the vehicle so when you push down on the back of the vehicle the flywheel and the bump box rubber wheel will make contact with enough pressure to turn the flywheel. Also there should be some tab's, posts (whatever you wish to call them) that you will mount onto the cover of the box. Mount them so that they will be located at each corner of the chassis. This will allow you to position the chassis in the same location every time also they will lift the chassis off the box top enough to not jam the wheels together.
Sorry its kinda long but enough to start you on the road.
Basher is offline   Reply With Quote
Old 06-03-2006, 09:26 PM   #3
dirtracer1's Avatar
the best way to align the starter wheel to the engine's flywheel is to remove the engine from the vehicle, then set the complete car (minus the engine) over the starter box. then press down untill the starter wheel comes up and into the opening on the chassis for the engine's flywheel. this is so the starter wheel will align and make contact with the engine's flywheel. the next step is to set your alignment pins to hold the chassis in that position. after you've done that, re-mount the engine and double check the alignment. hope that helps you.
here's a pic of my starter box i use on my 1/8th scale.
Losi 22
Losi 810-e
Losi SCTE
Losi XXX-MF2/CRC SC
B&T R/C - http://b-treman-rc.valp.net/btrchome.htm
dirtracer1 is offline   Reply With Quote
Old 06-03-2006, 09:36 PM   #4
dirtracer1's Avatar
another pic with a kyosho mp 7.5 on it.....facing the correct way.
Losi 22
Losi 810-e
Losi SCTE
Losi XXX-MF2/CRC SC
Old 06-03-2006, 09:38 PM   #5
dirtracer1's Avatar
a pic of my jammin on the same starter box (note....the alignment pins arn't set for the jammin on this perticular box).
Losi 22
Losi 810-e
Losi SCTE
Losi XXX-MF2/CRC SC
Old 06-03-2006, 09:40 PM   #6
dirtracer1's Avatar
last pic......you want the starter wheel to come up thru this opening in your chassis. the flywheel of your engine wheel be directly over this opening. again, i hope that this helps you.
Losi 22
Losi 810-e
Losi SCTE
Losi XXX-MF2/CRC SC
Old 06-03-2006, 09:46 PM   #7
dirtracer1's Avatar
if this clearifies things a little better for you, you want the starter wheel to face in this direction for 1/10th gas truck (off-road). you want it to face the other direction for 1/8th buggy off-road.
Losi 22
Losi 810-e
Losi SCTE
Losi XXX-MF2/CRC SC
Old 06-04-2006, 01:27 AM   #8
Default Re
thank you so much, because of that i got it all taken care of. you rock!
Old 06-04-2006, 03:57 AM   #9
ProudSavageOwnr's Avatar
Send a message via MSN to ProudSavageOwnr Send a message via Yahoo to ProudSavageOwnr
eerrr...u got any spares engines i can shove inmy savage? lol it seems like u got quite a few there....
FG leopard comp w/Trevor Simpson 28.5 bzm crank
HIP Baja 5sct
AE tc5 3.5t speed monster,Futaba 4pks
Raptor G4 ,Raptor e550,Gaui x5,Mini titan v2,Precision aerobatics bandit 4s monster,Carbon z scimitar Jr 11x
ProudSavageOwnr is offline   Reply With Quote
Old 06-04-2006, 03:51 PM   #10
dirtracer1's Avatar
i do have some spares.......however, they're not extras.
Losi 22
Losi 810-e
Losi SCTE
Losi XXX-MF2/CRC SC
Old 06-04-2006, 03:54 PM   #11
dirtracer1's Avatar
your welcome.
Losi 22
Losi 810-e
Losi SCTE
Losi XXX-MF2/CRC SC
duratrax starter box, and mcdaniel glow starter/with gauge knoxvillerocco R/C Items: For Sale/Trade 5 12-26-2007 08:52 PM
Starter Box + Lead Acid Battery + Glow Starter Michael_T Australia For Sale/Trade 0 10-27-2007 04:33 PM
Brand New Mugen Starter Box & HT Batteries Starter Box LiPo Battery TonysScrews R/C Items: For Sale/Trade 0 09-15-2007 01:09 AM
Starter Box TraDE, Ofna pink 12 volt motor box for AE silver starter box jabroni racing R/C Items: For Sale/Trade 0 11-21-2006 12:21 PM
F/s Mugen Seiki Pro Starter Bii Aluminum Purple Starter Box **new** fasthpir40 R/C Items: For Sale/Trade 7 02-03-2005 02:45 PM
