Old 06-01-2006, 12:27 AM   #1
duckbutter's Avatar
Send a message via Yahoo to duckbutter
Default need help on gearing the xxx b2k
my motor seems to get hot quick. If i run a 27t stock what gear ratio should i stay between so I dont burn out the motor. Also whats a good gear ratio for a 6.5 novak brushless. Im not sure if I should go up a tooth or down a tooth if the motor gets to hot to fast.
duckbutter is offline   Reply With Quote
Old 06-01-2006, 05:13 AM   #2
dragster's Avatar
All depends which brand 27t stock motor your using, 78spur 18-22 pinion,
Sponsored by my Wallet,
X5 4WD should of kept it.
Losi JRXS should of kept that also.
Li-po battery Technology F'kn Overrated
dragster is offline   Reply With Quote
Old 06-02-2006, 11:51 AM   #3
duckbutter's Avatar
thanks I try those ones
Old 06-02-2006, 02:21 PM   #4
That0neguy's Avatar
I made a gear chart that tell you what gearing per stock motor.Itsin the BK2/MF2 thread.
Hello.0
That0neguy is offline   Reply With Quote
Old 06-02-2006, 05:30 PM   #5
Rysuleod's Avatar
Novak has recommended gearing for their brushless systems in their instruction manuals.
Try this link:
http://www.teamnovak.com/download/in...rg_gearing.pdf
Rysuleod is offline   Reply With Quote
Gearing lickashotblaow Electric On-Road 0 07-29-2007 05:47 PM
NeeD Help with gearing please daver1 Electric On-Road 4 07-20-2007 09:12 AM
Gearing for TT-01 tl-01-jhb Rookie Zone 0 11-10-2004 05:35 AM
Need help gearing a TC3 fasda1 Electric On-Road 10 11-06-2004 11:51 AM
Gearing??? mike m Monster Trucks 3 01-24-2004 07:54 PM
