Old 01-07-2003, 10:07 AM   #1
Default Wheel Alignment
Fellas,
What's a good way to set up the wheel alignment on a Losi XXX4? Are there some good, inexpensive tools? Or do you just eyeball it?
Thanks,
Jack
jforkner is offline   Reply With Quote
Old 01-08-2003, 05:19 AM   #2
sosidge's Avatar
RPM's Camber Gauge is good - pretty much everything else you can eyeball or judge with a steel rule.
Old 01-10-2003, 07:04 AM   #3
Thanks Sosidge. I made a setup board to check toe-in/out and just used a small drafting square to set the camber. If my setup doesn't seem to work, I'll give your suggestion a try.
Thanks again.
Jack
Old 01-16-2003, 05:55 PM   #4
alignment check
Should toe/camber/caster be set with the cars wheels in the air or on the bench under its own weight?
(I've only experience with automobiles, which are set in the air)
axo959 is offline   Reply With Quote
Old 01-17-2003, 04:54 AM   #5
sosidge's Avatar
I do it under load - there's more play and flex in a toy car than in a real car.
Wheel balancer and wheel putty K.Copeland R/C Items: For Sale/Trade 5 03-16-2008 09:39 PM
KO Propo EX-10 Helios w/ Drop wheel extension and hex wheel adaptor Justin Zorc R/C Items: For Sale/Trade 6 02-28-2007 10:32 PM
Vintage RARE Kyosho Progess 4WS (4 Wheel Wheel Steering) assoc_driver Australia For Sale/Trade 0 01-16-2006 08:34 AM
WTB alignment jig JERRYT R/C Items: For Sale/Trade 0 12-01-2005 09:50 AM
·New TakeOff dish wheel VS Cross spoke wheel· ZER01 Electric On-Road 29 10-04-2003 05:14 PM
