Old 03-21-2007, 04:43 AM   #316
Company Representative
OLD 69's Avatar
Trader Rating: 44 (100%+)
Originally Posted by pitdog
hey ari you where contacted today by gerard from ozrc about the o rings for the spider gears part number 560104 as i didn`t need the gears i couldn`t afford $20 for o rings ,i understand there will be a part number for them later ,i did manage to track down 50 o rings for $9.50 from minature bearings australia here in brisbane a worth while part to stock up on try running with out them thanks for your help today
Yes there will be a separate part for the orings, i believe Magic has them now. I will be getting them in my next order. Good to hear you got yourself out of trouble.
Ari
OLD 69 is offline   Reply With Quote
Old 03-21-2007, 05:21 AM   #317
I am building my kit now, I have a question. On the diff ring gear and pinion, I put the spacers in the way the manual says but when I tighten it down in the front and rear boxes they seem alittle crunchy, not quiet at all, is this common until they break in? I did put some grease on the gears themselves. The shims are 2 on big gear side 1 on none gear side, and nothing on the pinion shaft but the 2 bearings. Am I correct?
Also the front aluminum hubs seem alittle tight for the steering is this common or could I have gotten alittle too much lock tight on the aluminum spacer in the C hubs and creating alittle binding? Whats everyones opinion? Other than those 2 things this kit is going to be excellent once done.
Thanks for your help
Warren
wardyl is offline   Reply With Quote
Old 03-21-2007, 05:38 AM   #318
THUNDERPAINT!'s Avatar
Send a message via MSN to THUNDERPAINT!
Warren
yes when you first build the car the gears will be 'crunchy', they bed themselves in after about a 10 minute run at which point you will need to reshim the diff to the bevel gear ... it is also good practice to always check the shim on the diffs regularly
as for the 'c' hubs i think you may have done something wrong mine turned freely out of the box
THUNDERPAINT! is offline   Reply With Quote
Old 03-21-2007, 07:24 AM   #319
When I disassembled it after I wrote this I noticed that the bolts that go through the aluminum inserts in the c hubs, some lock tight got onto it creating the binding, I am going to reassemble tonight, so all looks good for what I have done to date. Thanks for your help
Warren
Old 03-21-2007, 08:14 PM   #320
anytime warren!! anything else you need to know just fire away.... be more than happy to help
cheers
ben
Old 04-07-2007, 09:39 PM   #321
stump27's Avatar
stump27 is offline   Reply With Quote
Old 04-16-2007, 04:43 PM   #322
i got mine jumping of a metre high jump going about 12 to 13 metres (at the new sunshine coast off road track at mooloolah queensland)and found out the fuel tank has to much contact on the chassis and cracked it along the bottom so i put 4 one mill washers on it,1 on top of each post and 1 under the post next to the pipe so it had two washers taking it up 2 mill on the contact side, took it out again on the same jump for about a 4 hour test and problem solved but then the same jump i cracked the new designed wing from a bad landing but i can live with that i love the buggys design but the next model team magic they need to goto hudy sprung steel like mugen and xray and a more durable plastic then it will be perfect
www.pinehillsdirtracing.com...MUGEN MBX7R with TEKNO V4 conversion.....TEKIN RX8 GEN2 esc HOBBYWING motor 2200kv.....
pitdog is offline   Reply With Quote
Old 04-17-2007, 09:45 PM   #323
TonysScrews's Avatar
UPDATE!
Team Magic M1B "supplemental" screw kits are now in stock!
Team Magic M1B "supplemental" 207-piece high grade 12.9 alloy steel socket head screw kit. Kit includes all applicable cap, flat and button head screws, as well as nuts, washers and set screws in 3mm and 4mm sizes.
Unfortunately the 3.5mm screws are not available from my suppliers so they are not included. Team Magic sells some of the 3.5mm screws in individual packs, so please get these from your nearest Team Magic parts supplier. The 3mm x 23.5mm diff screws are a special item and I believe are only available with the diff parts. The 4mm x 12mm "special" button heads for the front knuckles are also not available seperately. And finally the 3.5mm x 26mm long flat heads for the upper shock mounts also do not appear to be available seperately.
Team Magic Part Numbers:
Part # 123510 - 3.5mm x 10mm Flat Heads (6)
Part # 123510C - 3.5mm x 10mm Cap Heads (6)
Part # 123512C - 3.5mm x 12mm Cap Heads (6)
Part # 123516BU - 3.5mm x 16mm Button Heads (6)
Part # 123518 - 3.5mm x 18mm Flat Heads (6)
Part # 123522 - 3.5mm x 22mm Flat Heads (6)
Part # 111147F - 3.5mm Nut (6)
Part # 126412EN - 4mm x 12mm Flat Round Head Engine Mount Screw (6)
Thanks and best regards,
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
Old 04-23-2007, 10:15 AM   #324
TMizzle's Avatar
Default race report
Rd2 of the Texas Invitationals
My car was excellent all weekend. I clearly had one of the fastest
cars at this weekends race!
RD1. Jason Branham sets the mark with a 13 lap TQ run.
My M1 was VERY good in my run but for some reason the lap counter
wasn’t picking up my car until the second half of the race and I feel
confident I would have turned 13 in RD1 but basicly it didn’t count.
I felt good thought because I knew my car was fast enough to run with
anyone.
RD2. Having a pretty good run, but unfortunately I lost a rear CVD pin
and had to pull off.
RD3. Another good run, on a fast 13 lap pace but I blew it on the last
2 laps with a couple bobbles. I found a new line that only the M1
could take. I was doubling the wagon wheel turn and triple doubling
the whoops section with ease. Many people commented on how
effortlessly my car went through that section. After RD 3 they had
open practice and I let 3 team drivers from other manufactures drive
my M1 and they were all very impressed and came off the stand with a
smile on their face.
RD4. Last chance qual. I needed 13 to get in the show… At the start
of the race Battaile and I took the early lead. One bobble and Mike
Battaile (Team Kyosho) started to pull away. After about 6 laps Mike
was on TQ pace and I was 8 seconds behind him. 2 laps later, Mike and
I both were on TQ pace when I pulled withing 1.5 seconds of Mike. I
got caught up with lapped traffic and feel off TQ pace as did Mike B.
I still pulled a 13 lapper which placed me in the A.
Starting 8th, I got off to a great start quickly taking 2nd and the
1st on the first lap. I held 1st for a few laps until I tagged a pipe
and just like that I was 10th!! For some reason my motor wasn’t
getting that great of millage so I had to pit every 5.5 minutes which
REALLY hurt me. 30 minutes later I was 6th. The M1 was great and
didn’t give me one problem all weekend
TMizzle is offline   Reply With Quote
Old 04-23-2007, 10:28 AM   #325
TMizzle's Avatar
Old 04-23-2007, 11:27 AM   #326
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
nice one TMizzle. too bad about the result. but your M1B seems to be ok. the engine probably still too rich. just a thought there. sometimes, luck do play here. next time friend.
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 04-23-2007, 11:37 AM   #327
vones's Avatar
new front arms cracked too easy.......
new support for fuel tank does not solved cracked fuel tank...changed to harder material.....
shocks piston outer diameter need to look into....
the 2 teflon support inside diff case cause inconsistency to diff settings.....
crown n pinion gear meshing too little.....
diff case screws too short.....
chassis too soft..i doubt it's A7075....maybe NICK of TM can provide the specifications...I'm into material purchasing....maybe TM's vendor shortchange you guys....FINALLY did you TM guys really test the buggy on the track with jumps or just flat surface??!!!
so much for now..
vones is offline   Reply With Quote
Old 04-23-2007, 12:20 PM   #328
TMizzle's Avatar
i havent experienced any breakage within the last gallon or 2 of hard running every weekend on many different tracks.
The fuel tank problem was fixed with the spares package.
crown and pinion meshing to little? Add a shim?
diff screw cases to short? Which ones??? the ones that hold the acutal case together or the diff case screws?
Chassis to soft? You mean the flex? If so, they designed it to flex alot for more traction. I havent had any bad effects from the chassis flex. It does seem to be wearing a little quickly but i do have about 3-4 gallons or more on it.
Old 04-23-2007, 08:46 PM   #329
vones's Avatar
wait and you shall find out for yourself...
the changes to the front arms is that the screw depth is reduced....buggy designed for experienced racers....I'm a newbie...so newbie BEWARE!!!
what does an extra support do to the fuel tank? It's the fuel tank material!
before you fix the crown n pinion hold it up in your hand and see the meshing...it's about 1/3
the ones that hold the diff cases together...3.5x10mm
I had mine for 20-30 gals since it first came out...this is my 2nd M1 and my 2nd chassis and I have 2 spares packages.Have you tried to see how much flex is in the buggy after a hard run?
I'm very sure Nick of TM knows SOME OF THESE highlighted points....I understand it takes time for a new buggy/car to evolve....but the spares packages is just a temporary solutions to problems....until I see some new changes to the M1..I have to say sorry to TM....money is in my pocket...
Old 04-24-2007, 12:16 AM   #330
vones's Avatar
TMizzle, from the looks of your M1...I can see you have some new prototype parts from TM...so that's why you didn't break anything....I rest my case.
Team magic 1/8th M1B buggy weaponx R/C Items: For Sale/Trade 38 07-27-2008 05:47 PM
wwt : A BRAND NEW TEAM MAGIC M1 buggy DOE BOY R/C Items: For Sale/Trade 16 06-23-2007 06:07 PM
Team Magic buggy M1B Quomingsua Singapore R/C Racers 0 05-27-2007 11:41 PM
TEAM MAGIC M1 BUGGY.. F/S bad-monkey R/C Items: For Sale/Trade 6 03-05-2007 08:08 PM
Team Magic M1 buggy JRSXrookie R/C Items: Wanted to Buy 1 01-24-2007 07:05 AM
