Old 03-13-2007, 02:13 AM   #301
Trader Rating: 49 (100%+)
Send a message via AIM to weaponx
Thanks for the explaination.
weaponx is offline   Reply With Quote
Old 03-13-2007, 09:01 AM   #302
There ia a writeup of this buggy in the April 2007 Radio race car mag
www.radioracecar.com ( you can only see the cover here)
Andyg01 is offline   Reply With Quote
Old 03-13-2007, 10:51 PM   #303
Hi Ari,
How much ride height are you running? Found the rear shocks on the front of car increase its minimum ride height quite a bit.
Cheers
Andrew
Lycan is offline   Reply With Quote
Old 03-14-2007, 01:06 AM   #304
THUNDERPAINT!'s Avatar
Send a message via MSN to THUNDERPAINT!
Originally Posted by Lycan
Hi Ari,
Cheers
Andrew
andrew,
we run the ride height so the driveshafts are level, see my set-up sheet i posted.... the only difference between mine and ari's was that i was running the new purple rear sway bar and my diff oils were slightly thicker
cheers
ben
THUNDERPAINT! is offline   Reply With Quote
Old 03-14-2007, 01:36 AM   #305
Thanks Ben.
I tried 1.7mm holes in my shock pistons with 30wt oil and they lacked dampening. Is this a typo?
Andrew
Old 03-14-2007, 01:44 AM   #306
Thanks Ben.
Andrew
yes it was i actually have 1.5mm pistons ....sorry
Old 03-15-2007, 09:59 PM   #307
hello~
Here is the M1B Review in Radio Race Car Magazine 2007 April:
TristaTM is offline   Reply With Quote
Old 03-17-2007, 06:33 PM   #308
TMizzle's Avatar
Talking best to date!
Wow!!
Car was the best its been to date today! No issues with the car all
day and i showed it no mercy and ran tank after tank after tank!
Once again i am just amazed with how good this car turns! Car was
very easy to drive. Took a few tanks to get the brakes 100% dialed
in. The car was a little loose on the rear but VERY controllable. I
don't remember spinning out once and we were on the slickest track in
U.S. History! Cool thing is they watered it a couple times and the
car was stupid fast. I had my little bs practice motor in, but
tomorrow we are hitting a different track and i plan on running my
real motor to really see whats up!
Couldn't ask for any more from the car at this point!
I will try to get some video of tomorrows practice session.
Setup i ran:
Front
5000
40wt
0 toe
-3 camber
Orange springs (rear)
Rear shocks
1.5 pistons
4000
Rear
3000
35wt
3 toe
-4 camber
purple springs
purple sway bar
option wing (up)
middle camber link
upper hole on hubs
1.5 pistons
TMizzle is offline   Reply With Quote
Old 03-17-2007, 07:53 PM   #309
Positive news
How much of a change did the option wing make?
Andrew
Old 03-17-2007, 07:56 PM   #310
TMizzle's Avatar
not sure how much was the wing because i tried many different things.
The wing is a must have though because it is A LOT stronger than the stock one. Much harder plastic.
Old 03-18-2007, 09:34 PM   #311
TMizzle's Avatar
NEW M1-B VIDEO (high quality... please be patient)
M1-B Video (medium quality)
Very slick track conditions...
Old 03-19-2007, 08:37 PM   #312
TMizzle
nice drive and nice video!!!
Thanks for sharing ~
Old 03-19-2007, 09:23 PM   #313
raced the car at canberra ( a very slippery track) last weekend qualified 4th and finished 2nd in the main (after dropping back to last after i made a mistake )
here is the set up i used ( then after the final i put the yellow front bar on and the car was much better )
Old 03-20-2007, 12:52 PM   #314
Thanks Ben.
Old 03-21-2007, 04:15 AM   #315
Originally Posted by OLD 69
Latest cahnges made to the M1 that really transform the car.
560540 Aero rear wing. Wider, higher down force and larger side plates. This wing plantes the rear end of the car.
We are also running rear shocks on the front. This changes is a must have, really ballances the car perfectly. All you need is the followig two parts:
560200 Shock body
560190 Shock shaft
Strip down your front shocks, use the rear shafts and body and put it all back together. When using this change, run the middle hole on the tower and "always" eun the outside hole on the arm.
Trust me you will love these two changes.
Cheers
Ari
hey ari you where contacted today by gerard from ozrc about the o rings for the spider gears part number 560104 as i didn`t need the gears i couldn`t afford $20 for o rings ,i understand there will be a part number for them later ,i did manage to track down 50 o rings for $9.50 from minature bearings australia here in brisbane a worth while part to stock up on try running with out them thanks for your help today
www.pinehillsdirtracing.com...MUGEN MBX7R with TEKNO V4 conversion.....TEKIN RX8 GEN2 esc HOBBYWING motor 2200kv.....
pitdog is offline   Reply With Quote
Team magic 1/8th M1B buggy weaponx R/C Items: For Sale/Trade 38 07-27-2008 05:47 PM
wwt : A BRAND NEW TEAM MAGIC M1 buggy DOE BOY R/C Items: For Sale/Trade 16 06-23-2007 06:07 PM
Team Magic buggy M1B Quomingsua Singapore R/C Racers 0 05-27-2007 11:41 PM
TEAM MAGIC M1 BUGGY.. F/S bad-monkey R/C Items: For Sale/Trade 6 03-05-2007 08:08 PM
Team Magic M1 buggy JRSXrookie R/C Items: Wanted to Buy 1 01-24-2007 07:05 AM
