New Team Magic Buggy!
#196
Here is a video of my M1 with the GO 5 port (not fully broken in) from yesterday. I started 2 laps down so i was driving a little crazy but there are a few good laps in there.
Team Magic M1 Video
Team Magic M1 Video
#197
i was looking on the net and the best motor i can find is a boss b21 rally it reves out at 48 000 rpm lol but i cant find any in canada so and im limited to a .21 in the buggy class im runing in so ill just have to find a substatute for it
#198
man that car is so sick i got mine on order and it should be here in a week and i cant wait to race it lol do u see any weak parts on it or parts i should orde to have on hand if they do break
#199
Team Magic M1 Video
Team Magic M1 Video
I'm not knocking your driving , but that track looks like it is a drift track . I liek the track also but seems liek its missing some dirt.
#200
its a semi-blue groove surface.
in the goove it crazy traction, but get out of it and its VERY loose!
i wil admit, that was probably my worse run of the day. sucks we taped that one. lol
#201
Well lets try and stay in the groove then shall we .
#202
hahah. ok... i will next time.
#203
totaldomination:
There are a few weak parts on the car. Recommend replacing the top front turnbuckles (part# 116153W) with something bigger/stronger.
Replace the centershaft 8x16 bearings that support the bevel gear with 8x18 (4 in total)
Reduce up-travel on front shocks by 4mm as the UJ's tend to pop out.
Make sure you shim the diffs nice and tight to start with otherwise you will strip the gears. Recommend 2 shims on gear side and 1 on the other.
You will need rear toe and anti-squat blocks for the rear.
Part#'s 506501, 560505, 560506 and 560507
Recommend replacing front shock shafts with rear to allow more droop.
Once you've built the car, make sure you put in on setup guages. I found the measurements supplied during building didnt even come close to the stock setup.
#204
No, the kit doesn't come with a motor or radio gear. It isn't a ready to run.
A good motor would be the OS VG, Werks B3, STS... plenty more but all those are under $200 and very good.
#205
lycan
hey man thanks 4 the tips
#206
Originally Posted by Lycan
totaldomination:
#207
i haven't experienced any of those issues...
#209
Team Magic M1 Video
Team Magic M1 Video
TMizzle, Nice track, where is it?
#210
that track is here in Houston, TX. there is another indoor track 1 exit down from this one.
