Old 05-22-2006, 12:44 PM   #1
Default New to R/C. A couple noob questions.
I just recieved my electric RTR Rustler and it didnt take me long to realize I didnt have the right type of battery charger. I have a Team Orion 3300 NiMH pack and apparently the Tower Hobbies charger that I ordered only charges Nickel Cadmium packs. So now I'm looking for a very cheap NiCad/NIMH charger and was wondering if this one :
http://www2.towerhobbies.com/cgi-bin...?&I=LXHJB5&P=0
would suit my needs. The only thing that worries me about this one is that it says DC only. I'm new to R/C and all electronics in general so I'm really not sure what that means. I know the power in a wall outlet is AC so does this mean I cant charge it in my house? Anyway, If this charger wont work for me a suggestion to a low price one would be great!
J_ROD48 is offline   Reply With Quote
Old 05-22-2006, 02:29 PM   #2
Please someone help me out. I'd really like to start running my truck.
Old 05-22-2006, 02:50 PM   #3
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
First, internet forums are an evolving creature and you won't always get an instantaneous response. Give it a couple more hours without a response before freaking out.
Yes, DC-only (direct current) chargers require a 12-volt power source, like a full size car battery or a constant current power supply. You cannot plug this into a wall and charge your batteries in the house without one of the two. Just starting out, you are best off looking for a charger that is listed as AC/DC. There are a few decent options out there in the entry level range, but you will pay a little more for one with the ability to use both AC current (110v house outlets) and DC current (12v).
Someone else may be better suited to make a recommendation for an entry level charger that I would.
Good luck,
doug
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Old 05-22-2006, 03:02 PM   #4
Unfortunatly, there are not alot of cheap ac/dc chargers that will work on NiMh batteries. Buy the best your buget will allow. You will be better off in the long run. Many of us went the cheap route and now have spent more money just upgrading.
That said, DuraTrax makes a few good ac/dc chargers. If you can afford it the Duratrax Ice will charge just about everything you need, even LiPo's when you make that change. However, it is a DC only charger. You will need a power supply for it.
Any cheap charger that does not have an adjustable Delta Peak needs to be monitored so the battery does not overheat. NiMh batteries should never get above about 140.
Goog luck.
ddcarter3 is offline   Reply With Quote
Old 05-22-2006, 03:20 PM   #5
Flying_Ace's Avatar
If your not charging lipo's, I would go with a Duratrax Pirahna.
Brady Janson
www.racetechhobbies.com
Flying_Ace is offline   Reply With Quote
Old 05-22-2006, 03:21 PM   #6
squarehead's Avatar
[sidebar] ddcarter3, your screen name freaks me out every time I see it. We seem to share last names. [/sidebar]
doug
Everything depends.
Nothing is always.
Old 05-22-2006, 04:04 PM   #7
A great one it is. I have had it for 44 years.
David D. Carter III
Seems we share almost the same RC rides also.
Old 05-22-2006, 04:38 PM   #8
Thanks for the replies, right now I'm looking at the duratrax line and it looks like I'll buy one from them. Again thanks for helping a newbie.
Old 05-22-2006, 04:52 PM   #9
Trader Rating: 14 (100%+)
take a look at the tekin bc112c. It is ac/dc and can be found for $160 new. This in my mind is a far superior charger to the duratrax you were looking at.
But it is your call, just giving you another option!
o.s. power is offline   Reply With Quote
Losi XXX-T noob questions Joel78 Electric Off-Road 9 01-27-2008 10:13 AM
NOOB battery questions beast95451 Electric Off-Road 9 03-16-2007 07:53 PM
am a noob and questions ironman89 Rookie Zone 0 12-04-2006 07:40 PM
R/C noob here! Bought a TC3 and have a couple of questions.. sebring_c5 Electric On-Road 4 09-15-2005 08:09 PM
Noob Questions EvilMunky Electric Off-Road 2 07-30-2004 07:08 AM
