Old 01-04-2003, 08:28 PM   #1
rdub202's Avatar
Trader Rating: 19 (100%+)
Send a message via AIM to rdub202
Default Indi reactor 20
i just recently got an Indi Reactor 20a discharger for a late christmas present and it has NO DIRECTIONS!?!?! do i just clip it on and let it go or what. help would b greatly apprreciated.
rdub202 is offline   Reply With Quote
Old 01-04-2003, 11:19 PM   #2
fabolousRC's Avatar
Send a message via AIM to fabolousRC Send a message via Yahoo to fabolousRC
if you have a fully charge battery, you want to clip both negative and positive end of the discharger to the same points on the battery's connector. THen, press that large yellow button and watch until all the LED lights are gone. The discharger will stop working by that time and your battery should be at the 5.4V (6 cell) mark.
Tamiya DB01 Durga\Kyosho Lazer ZX-5\Kyosho Turbo Optima
Lex Tyler Paints \ Norcal Hobbies \ Bay Area Peninsula R/C Club
fabolousRC is offline   Reply With Quote
Old 01-05-2003, 09:13 AM   #3
rdub202's Avatar
thanks, but what if the batt is nearly dead do i do the same thing?
Old 01-05-2003, 11:07 AM   #4
fabolousRC's Avatar
NOPE. Especially when the discharger thinks the battery's power is waaaaayyyy below 0.90V/cell (equals to 5.4 Volts). I have reactor 30 and it is a lot faster to discharge than the "20" but basically it is the same thing
Old 01-07-2003, 03:30 PM   #5
rdub202's Avatar
im confused, u said nope and then didnt tell me to do ne thing different. i just tried it...i clipped both things then the fan clicks on then i push the start button (BIG YELLOW BUTTON) and then it makes a weird noise and all of the lights light up??
Old 01-07-2003, 03:55 PM   #6
rod_b's Avatar
Send a message via AIM to rod_b
If it has enough juice to be over the cutoff, it will come on...which is probably what happened to you. When the lights go off and you hear the pop (of the button releasing), then your batts are discharged at or below the cutoff. No additional discharging is required unless you want to put them on an equalization tray. I believe it is recommended that you remove the batts from the discharger as soon as the lights go off because the fan will continue to draw power from your batts and you don't want to run them down too low.
rod_b is offline   Reply With Quote
Indi Reactor 30 bibleboy R/C Items: For Sale/Trade 15 11-14-2008 09:31 AM
Indi Reactor 30 dodgeguy R/C Items: For Sale/Trade 0 04-10-2008 08:52 AM
Indi Reactor 20 rccars R/C Items: For Sale/Trade 5 02-02-2008 10:49 PM
INDI Octane 2 Discharger 20A Individual & INDI Reactor 30 jrighter R/C Items: For Sale/Trade 6 01-19-2005 09:43 AM
Indi reactor 30 and Indi 16x3 pro v2.5 ni-mh weidjd R/C Items: For Sale/Trade 4 03-31-2004 04:04 PM
