Old 10-30-2006, 04:57 PM   #241
kdub's Avatar
Maifield and Tebo's GT2 setup from Reedy Truck Race is online at the AE site.
Chief Engineer, Schelle Racing Innovations, SchelleRacing.com - Team Associated - Reedy - JConcepts - Sanwa - MIP - StickyKicksRC - UpGradeRC - Darkside Designs
kdub is offline   Reply With Quote
Old 12-03-2006, 11:22 PM   #242
Eggyolkeo's Avatar
Hey Jared,
What setup are you running for Aussie tracks? I'm in the process of getting mine together.
Any building or setup tips you can offer? Tires?
I'm thinking about using an OS TZ engine but haven't made the purchase yet.
Eggyolkeo is offline   Reply With Quote
Old 12-04-2006, 09:20 AM   #243
RCBLUE's Avatar
The TZ is a wicked fast motor and would be a great choice. I have a TR but after seeing my frinds GT2 with a TZ I told myself that I will have one by summer time. As far a building tips, first and formost replace all the 2/56 button head screws including the ones for the nose brace.
Don't sweat the petty things...........Pet the sweaty things!!
Serpent America
Lunsford Racing
RCBLUE is offline   Reply With Quote
Old 12-11-2006, 12:32 AM   #244
Bigedmond's Avatar
Trader Rating: 18 (100%+)
Maybe its just me, but my gt2 feels like the clutch is slipping before im through a tank. The white plastic shoes really seem soft, and i only have roughly 10 tanks through it. Also, i cant find replacement shoes, so um, its buggin me. Making me think i should have stuck to losi
Bigedmond is offline   Reply With Quote
Old 12-11-2006, 03:03 PM   #245
Default slipping
I'm having the same issue with the slipping....mine slips like a mutha. I am no expert, but I've tried tightening down the slipper, and no result. The only other thing I can think of is the clutch shoes not gripping the inside of the clutch bell OR not having enough shims in the shaft.
any thoughts?
MikeyG is offline   Reply With Quote
Old 12-11-2006, 04:05 PM   #246
kdub's Avatar
Make sure the clutch bell is clean on the inside. Grease from the bearing can cause an issue, so use motor spray to clean the shoes and inside of the clutch bell.
We haven't had any clutch slipping problems once we got everything cleaned up.
Old 12-11-2006, 05:23 PM   #247
Trader Rating: 25 (100%+)
Hey,
Been running Losi Studs ( red ) and Boe Tie Tires.
Used to run blue front and silver rear springs. but found it grips better all round if u run silver all round.
Goodluck.
Run a shorter wheelbase to. Like bring the rear wheels closer to the front, using the shims on the hubs.
Goodluck.
JK
" It takes a lot of things to go right, but only one thing to go wrong to lose a race "
HEI | NBHC.com | Model Engines | World Hobbies
Jarred King is offline   Reply With Quote
Old 12-11-2006, 09:14 PM   #248
Bigedmond's Avatar
Well, i am ordering new clutch shoes, and a new bell. I am going to clean it with alot of motor spray, then scotch brite it a little to scuff the surface. I'm thinking about getting softer springs as well.
Old 12-11-2006, 11:01 PM   #249
WheelNut's Avatar
Send a message via MSN to WheelNut
Considering buying a GT2. What I need to know though is, how similar does this truck behave compared the T4? (excluding the power delivery of the nitro motor of course) I ran a GT last year for one race and it was horrible (completely hopped up with all the stuff the team guys were running as well). If the GT2's handling is close to the T4's I think I will pick one, damn I love the T4! So good for me (got the 2 Canadian national wins to prove it ).
•Brad Comis
WheelNut is offline   Reply With Quote
Old 12-12-2006, 01:52 AM   #250
Talking
When you gun it or give it some gas on a strait, the engine revs up like something is sliping right?
I had the same problem but its was not the clutch. It was the diff. It was too loose. tighten that diff down some and you will see what I'm talking about.
mgreen is offline   Reply With Quote
Old 12-13-2006, 08:18 PM   #251
RCBLUE's Avatar
Buy one you wont regret it. I have had several Losi guy comment on how my truck handles the jumps and corners. I am running on an indoor clay track (till summer) with a huge technical tripple. Several Losi gas trucks with the same motor that I have (OS .12tr) have tried the tripple and died horrible deaths. It is an awsome truck and given the amount of abuse I have given it, I'd say it is very tough. A++++
Serpent America
Lunsford Racing
Old 12-14-2006, 04:26 PM   #252
pumpkinfish's Avatar
Is that your EDM? Am I right that I see touring car shocks on the front? PM me about the conversion as I have been kicking around converting my GT2 for oval duty.
Yokomo YZ-2, B-Max4 III
Kyosho RT6
Losi 22b, XX4 Worlds
Associated SC10.2, RC10B2, RC10T2, RC10
pumpkinfish is offline   Reply With Quote
Old 12-15-2006, 09:40 AM   #253
Thumbs up
Thats right. Nitro TC3 shocks upfront. It makes a big difference on Dirt Oval.
Old 12-20-2006, 12:02 AM   #254
how do you guys like your gt2's? would you reccomend one for someone new to 1/10? i'd probably just pick up the rtr version. also my lhshops dont carry parts for it, meaning i'd have to get whatever i break off of tower if i needed to which kinda sucks.. should i still go for it? also whats up with your slipper clutch problems, have you found solutions to them yet? thanks guys
rally is offline   Reply With Quote
Old 12-20-2006, 01:40 AM   #255
WheelNut's Avatar
What kind of hobby shop doesn't carry Associated?! That must be one sad shop. The shop in Kelowna I'll bet carries Associated parts, that'd be a lot faster than getting them from tower. Anyhow, I haven't got a GT2 yet, but I will be soon, and based on previous expirences from AE cars they are all really good (I've had about 7 different ones). The GT2 is actually quite beefy as well, I could hardly believe it when I first saw it actually, it really does look very stong. If you want to try and convince your LHS to carry AE stuff just PM me and I'll give you the number for a AE distributor in Abbotsford.
•Brad Comis
