Old 04-26-2006, 12:33 PM   #1
SteveJa's Avatar
Trader Rating: 17 (100%+)
Default help with B4 setup sheet
I am trying to copy a setup sheet to my car.... thing is i dont understand a few things on it......
first off..... the battery placement...... it has the front checked on it.......so does that mean the battery is all the way to the front.... or does that mean the foam is in the front ????
other thing is..... on the shocks....... for the limiters they have marked....
"the front shock bottoms are unscrewed two full turns"
i have NO idea what that means..... please help me on this one......
last thing... steering block....... trailing or inline........... I have a FT B4 and i am unsure of what it comes with ?
Thanks for all the help
SteveJa is offline   Reply With Quote
Old 04-26-2006, 01:00 PM   #2
front battery placement is battery towards front, foams in the rear,
as for you r other questions here is teh tuners manual from associated, shoudl cover all your questions
http://download.teamassociated.com/p...HandbookV2.pdf
Rod
gatermaxx is offline   Reply With Quote
Old 04-26-2006, 01:29 PM   #3
Trader Rating: 39 (100%+)
For the front shocks, it means there isn't any front limiters added inside of the shock. What they mean by the shock bottoms are unscrewed two turns means just that. If you take a look at the bottom of your shock shaft, there is a plastic eyelet with a pivot ball on the inside. That plastic eyelet is what gets turned out two full turns. Make sure the eyelet is fully bottomed out on the shaft before doing your 2 full turns out. This will add more downtravel to your shock in the front. On my B4, I personally run one limiter in the rear and turn the front eyelet out 1.5 turns.
Chuck
www.ridgewaybodies.com
https://www.facebook.com/ridgewaybodiesRC/?ref=hl
ridgewaybodies is offline   Reply With Quote
Old 04-26-2006, 01:39 PM   #4
SteveJa's Avatar
ok cool..... so does the FT B4 have trailing or inline steering blocks......
Old 04-26-2006, 01:53 PM   #5
The FT B4 comes with trailing. In most of the time, trailing blocks work the best. The inline will give you aggressive steering. An easy way to tell is if the axle is behind the vertical king pin, its the trailing axle. If the vertical king pin passes through the steering block, then its inline. The inline axles are optional, no kit comes with them.
Chuck
Setup sheet for TT-01R #88driver Electric On-Road 2 08-06-2008 10:52 AM
Setup Sheet For A Tb Evo 2 shortyzz Electric On-Road 2 01-02-2004 06:25 PM
MBX PRO setup sheet? cornflake Electric Off-Road 0 10-02-2003 11:31 AM
MBX PRO setup sheet? cornflake Electric Off-Road 0 10-02-2003 11:21 AM
Setup Sheet for Pro3.5 Silent Strike Electric On-Road 1 04-27-2003 10:15 AM
